Philips w66erf042x044 LED
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
LED LIGHT BLINKS 7 TIMES FAST OVER & OVER
Call philips to talk you through the reset option or arrange a replacement it may have a higher warrenty
Dec 21, 2011 | Philips Televison & Video
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
My philips 50p8341 beeps then flashes the red led 4 times
4 Blinks means that an incorrect voltage had been detected on the +5V circuit coming from PSU to digital control board.
The PSU must be tested and eventually repaired or replaced.
Aug 08, 2009 | Philips Televison & Video
I have the Philips 27PT6441/37 TV that turns on to the point of hearing sound then instantly turns off and flashes the led 3,2,1.
Plus horizontal lines on top of the screen
Jul 08, 2009 | Philips 27PT6441 27" TV
Philips 21'' L01.2A AB Chassis; Dead, Standby LED off.
it.s possibly a fuse, or a resistor, or regulator or all of the above
Jun 08, 2009 | Philips Magnavox 27MS343S 27" TV
Philips 42fw3090/17 don't turn on, only LED comes on red
first thing i would do is take the lamp out and look at it, it dhould be on the left side of the tv, you will see a little door at the bottom
Jan 10, 2009 | Philips Televison & Video
Philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
