Question about Cyclops Nexus Hid Rechargeable 3200 Lumens Spotlight, Black Hid5 Flashlights
Cyclops 3200 spotlight when turned on nothing but bat indecator lights red and yellow flicker and green full charge light stays on nothing from light itself
Charged as recommended tried new batteries still nothing
2 Suggested Answers
SOURCE: cyclops 6.5 halogen will
This is an easy fix. I just fixed mine literally five minutes ago. You'll need two 6v sealed rechargeable lead acid batteries, duct tape, and a #1 Phillips screwdriver. Take the two Phillips head screws out of the black lens bezel. They should be oriented on the side of the bezel at approx 3 and 9 o'clock. Rotate the bezel about an inch and the bezel should cone off. Disconnect the ground white wire to the reflector housing on the back of the lens. It should be screwed in. Next disconnect the positive wire. It should be red or blue. Mine was red coming from the switch and blue going to the light. Next unscrew the 4 Phillips screws around the white plastic cover that holds the batteries in. You'll see the batteries now. With your phone, take a picture of the wiring. Or make a note of it. Change the old batteries with the new, minding the wiring, and then reassemble. Should be fixed.
Posted on Sep 01, 2011
Does a light come on when charging and it's turn off
Normally it`s red when starts in charge and then turns green when full, if not your have problem named lost memory bat, use a flashlight to spend the rest of the battery, then try to plug in the appliance if want red continue charge until green light appear. Rather complicated but is actually very easy to do.
Nov 12, 2016 | Cameras
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
Recharging - indicator lights when complete
When the green light stays on that means the battery is fully charged. The correct charger for that light is a Class 2 Transformer
Model: KA12D120030042U It has a output of 12VDC at 300 mA
May 29, 2010 | Vector 2M Pwr Rch Spotlight
How do i find charger for cyclops 15 million candle power
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
May 19, 2010 | Camping, Backpacking & Hiking
It has been charging for days, but only the red & yellow lights come on. Shouldn't the green light shine when charged?
The battery is dead, a usual full charge for your sealed lead-acid battery takes only 10-12 hours. You can purchase a new battery from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69415&tid=15522
Feb 12, 2010 | Vector 1 Million Rechargeable Spotlight
Cyclops spotlight wont charge
It is indicating that your battery needs to be replaced, it will not hold a charge.
Oct 23, 2009 | Camping, Backpacking & Hiking
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Cyclops Nexus Hid Rechargeable 3200 Lumens Spotlight, Black Hid5 Flashlights Logo
Top Cyclops Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cyclops Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
