Question about Arctic Cat Winter Sports
Will not shift into reverse while running - Arctic Cat Winter Sports
Why My 97 mazda protege will not shift into reverse?
Sounds like wear on the selector lever, is the oil up to the running mark?.
Jul 01, 2014 | 1997 Mazda Protege
Hard shifting into & out of reverse when running
either your idle is set too high or your centrifugal clutch is broke
Feb 20, 2014 | John Deere Gator XUV 4x4 550 S4 ATVs
Dies when put in reverse
Make sure you can see what is happening when you shift into reverse (not running of course) and you should be able to find problem. Most likely the safety shutoff is being actuated while shifting into reverse.
Oct 17, 2013 | ATVs
91 legacy wont go into gear runs and you can shift thru the gears push in and let out clutch nothing get a kittle grind sound when you try reverse
could be shift fork thats in the tranny or it you could have snapped the main shaft not an easy fix you might want an expert mechanic to take a look at it good luck
Jan 25, 2013 | 1990 Subaru Legacy
I have a F250 lariat with a 460 - truck stalls when I put it in gear - even after it runs for 20 min. Sometimes it will stall while I'm driving. I had carborator replaced last year. Hope you can help.
Some possible causes could be:
Vacuum leaks cause an engine to run lean witch can cause the vehicle to stall when put into gear.
Improper base idle adjustment can cause the vehicle to stall when shifted into drive or reverse
A malfunctioning or damaged carburetor can cause the vehicle to stall when shifted into drive or reverse
Improper ignition timing can cause the vehicle to stall when shifted into drive or reverse.
A malfunctioning or damaged transmission or torque converter can cause the vehicle to stall when shifted into drive or reverse
Oct 31, 2010 | 1987 Ford F 250
2002 Volks Jetta GLS-difficult to shift into reverse gear
no recals but if you are the oreginal owner you have untill 2010or 80,000 miles before the warranty runs out, and if you are past that I bleive you will need a T.C.M transmission control module.
Sep 11, 2009 | Volkswagen Jetta Cars & Trucks
Wont go in reverse
get the selectors checked and ajusted........
Jul 06, 2009 | 1991 Honda Accord
The trans. stays reverse no matter what gear you put it in
It may be a shift fork or a synchronizer stuck Try running it around alittle in reverse and see if iy helps. good luck
Mar 27, 2009 | kawasaki W 400 Motorcycles
Can not get car into reverse
Try puttingi t in reverse with the engine off.
Usually the sign of a worn clutch
Nov 04, 2008 | 1998 Dodge Neon
1990 Toyota 4runner wont go into 5th or reverse
They had a problem with this plastic washer that is in the shifter tower it sits just under the shifter it self and gets worn out and causes this to happen- hope that helps.
Nov 03, 2008 | 1990 Toyota 4Runner
Winter Sports Logo
27 people viewed this question
Top Arctic Cat Winter Sports Experts
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
