Hi, I have numeric 600 Digital UPS, it is auto shutdwn when only modem is connected (low power), How can I disable this feature of auto shutdown during less loads
hotratchet
  • 952 Answers
SOURCE: The ups is shutting down immediatly ,once the AC power is off
thats a dead UPS... battery is bad now... you probably need to have it changed...
Posted on Jul 09, 2009
  • 192 Answers
SOURCE: My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
Posted on Jul 27, 2009
SOURCE: numeric ups with fault indication
Please Change Battery or Check the PCB Masfecter
Posted on Jun 17, 2010
SOURCE: Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
Posted on May 14, 2011
vjanand23
SOURCE: How to charge UPS
iam having numeric digital 600-ex-c ups but it making sound when we on the ups .... how i can charge it?
Posted on Jun 20, 2012
Hi, i have an APC UPS with model BE 500R PH how to bypass the auto shutdown of it?
On mine, until an electrical storm, was controlled through my computer via USB. Now, it shuts down in 5 seconds. I'm sure it's the thermistors, but I don't have time. Also, check for timing circuits.
Apr 26, 2015 | APC Computers & Internet
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
Numeric 600 ex redlight indication problem
i m the service technician of computer, cctv, printer ,monitor, ups etc.. numeric ups 600 ex problem red light and long beep .......
the problem is ups transformer ,, change or rewinding the transformer problem will be solve
Mar 02, 2014 | QVS NetStar (UPS650A) UPS System
Numeric ups
That means the battery in it is probably bad.
Aug 19, 2013 | Car Audio & Video
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
My numeric 600 plus ups swithched off automatiocally when power goes off not a single second back up its provided
Did it work before?
If so, then it has developed a fault. Check the battery fault light on the UPS panel. Perhaps it's battery is dead, or batery charging circuitry is faulty. Anyway, it would most probably need professional attention by a serviceperson.
If it did not, double check whether you have connected the computer etc. to the proper sockets - many UPS devices have a couple of UPS-powered sockets plus additional sockets with surge protection only (no UPS power!) for high power devices like laser printers etc.
Please come back and leave a rating/testimonial if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 30, 2011 | QVS NetStar (UPS650A) UPS System
Jul 09, 2009 | QVS NetStar (UPS650A) UPS System
Numeric ups with fault indication
Oct 14, 2008 | QVS NetStar (UPS650A) UPS System
How to charge UPS
Jun 05, 2008 | QVS NetStar (UPS650A) UPS System
Computers & Internet Logo
David Payne
David Payne
