Question about Brother MFC 210C All-In-One InkJet Printer
Geting error message now
I posted earlier with a problem with my printer, and now that I tried what they said  my "Photo capture" "Copy" "Fax" and "Scan" buttons are all flashing, and the display is showing "Machine error 31". Hopefully someone can assist me in trying to solve this problem. Thanks again.
  • 832 Answers
Sure.
Press 9 then 9 to leave the maintenance mode.
Did you had a paperjam the days before? The error 31 indicates that there are obstacles on the pathway of the printhead. Another reason could be that the encoder strip might be stained with ink.
See here how to open the printer cover:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(it s german)
Have a control check if there are paper pieces or something else on the pathway of the printhead. Check the encoder strip (the foil parallel to the path way): Is it clear or is there some ink on it? If yes, try to clean the encoder strip with water.
Leave the cover open and reconnect the flatcable and the cables back to the main pcb. The scanner on the left hand side upright to the open printer (looks like this:  I__  )and power up machine. Watch the printhead travel from right to left. Does it stuck somewhere?
Reassemble the printer afterwards.
When you dont get the printer back to work, there could be some more serious. you cant fix that by yourself, because you need some spareparts which are more costly than a new mfc!
Posted on Oct 26, 2007
SOURCE:
I get a 2200 message from my lexmark717 how can fix it?
The 2200 error message indicates that the scanner has stalled/jammed. This article in the Lexmark website will help fix the problem: 2200 Error on the Lexmark X7100 Series All-In-One
Apr 20, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My printer is displying an error message, saying- cartrige error, what should I do.
hi!!!! in that case there's a big possibility that your catridge was defective. Try to install another cartridge if that error message will pop up again.
Apr 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Fax
I would think so. I have the magic jack and I can fax using it. I have the same problem wih getting the error messages but the faxes are being sent, I call and confirm.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lost the cd how to install printer to comp again?
plz check the manufacture website for the driver download
Jan 13, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have an error message 1203 how can I fix
Electricial short in ink cartage. Try removing the cartage , clean the contacts on it and on the machine with a pencil eraser, making sure none of the contacts are touching one another.
Jan 01, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 1203
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Jul 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
*9*
mambari sel week plz chot the sel
Dec 08, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Not printing
hi i have similar problem .error code 5a .can you help ?
Oct 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
248 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
