Question about Electronics - Others
Panasonic sa pm46db
How to clean heads
How to connect a turntable to my Panasonic sc-pm46db cd stereo ?
You only have a USB connection. Traditional turntables cannot be simply connected. Get a USB turntable and you are all set.
Nov 12, 2013 | Sony HOME THEATER SYSTEM System
I need a manual for a panasonic sa-pt950
The Panasonic website should have a free PDF of it!
Mar 24, 2013 | Panasonic Sa-pt950 Receiver Only For...
How do you clean a lens in a 5 cd changer panasonic sa-ak27
You should take it out, wet some cotton sticks with WD40 and some ethanol and then clean it with it, the stick must be just slightly wet
Jan 22, 2013 | Panasonic SC-AK27 Shelf System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT75 doesn't recognize disk
First clean the laser lens with a cleaner disc,if don't work you gotta clean it manually with a q tip wet on alcohol clean the lens then with the dry side finish the clean.Good luck
Jun 02, 2008 | Panasonic Audio Players & Recorders
Panasonic home theatre system 5 cd changer says no play when inserting dvd
Try cleaning the pickup with a cleaner disc-i'm assuming this unit IS supposed to play DVDs, of couse!
Stan
Mar 19, 2008 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HE100 Remote
Look here:
http://www.pasc.panasonic.com/Epartr/PartsList.asp
Oct 15, 2007 | Panasonic SA-HE100 Receiver
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
