Question about Bisley Retail Supplies
Mobile filing system handle loching stud has the spring adrift and does not lock.
The right passenger door does not open from inside and out side
Find someone with a suitable door release jemmy or entry tool that can release the door lock down the window edge. When open, remove the door trim, access the lock and work out what's wrong. There are rods from the door button and inner handle that may have come adrift.
Jun 02, 2015 | 2004 Audi A6
Driver door internal locking not working
Remove the internal handles, remove the inner door panel and have a look at what's come adrift. Usual issue is the rod from the handle to the door lock has disconnected.
Feb 18, 2015 | Mitsubishi Lancer Cars & Trucks
Why wont the pull cord return/
use graphite powder in the spring and lock palls undo the lock screw and place a small flat washer between the cover and the body to give the return spring more room to move when the screw is tightened up.
Dec 04, 2014 | Cars & Trucks
Throttle connections on poulan pro 210 chainsaw
The precision bent throttle connecting rod can only go in one way CORRECTLY.... if it has to be forced or bent, stop and figure out the puzzle before any damage is done.
I'd suggest placing the carb temporarily on the mounting studs on the side of the cylinder. Don't install the filter and nuts etc yet. Take the throttle rod and lay it in place this way and that way until it looks like it matches the trigger end AND the carb end. Usually the carb end has to be installed on the carb while it is removed from the engine as tightness of space won't allow moving it all over to poke it in the hole. Once it is on the carb and you are sure of the orientation, slide the carb once again over the studs and lay the throttle rod by the trigger.
You need about three hands to hold the trigger, trigger lock, trigger return spring and the handle together while you figure out how to snap in the top of the handle and start a screw under the handle.
Jun 20, 2014 | Poulan Garden
Can not open all doors by keys and inside button,only trunk is working,i did check fuses,this happen when my battery went dead !
the lincage rods between the handle and the door latch must be adrift,the locking motors may be jamming the locks
Jul 05, 2010 | BMW X5 Series Cars & Trucks
Door locks won't work with the key
there are rods which link the handles to the door latch and clips secure, clip may have broken and rod adrift
Jul 05, 2010 | 1993 Chevrolet Lumina
Retail Supplies Logo
316 people viewed this question
Top Bisley Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Bisley Retail Supply Expert? Answer questions, earn points and help others
