Question about Mitsubishi Televison & Video
Hook up mitsubishi HS-U557 VCR to cable box - Mitsubishi Televison & Video
5 Suggested Answers
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Posted on Jan 18, 2008
  • 153 Answers
SOURCE: is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
Posted on May 13, 2009
SOURCE: Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Posted on Sep 17, 2009
  • 3 Answers
SOURCE: Mitsubishi HS-U540 VHS VCR How
The RED is Right Speaker the WHITE is Left Speaker and the YELLOW is for
Video. They connect with RCA Cables to the same color coded inputs on yout TV.
You may find it easlier to just use a CoAxial Cable; Use a CoAxial for the CABLE IN to the Cable Box then 1 CoAxial from the Cable Box OUT to the VCR IN then use 1 OUT from VCR to TV IN. That is much easlier then using RCA Cables.
Posted on Nov 30, 2011
Mitsubishi HS-U540 VHS VCR How do you connect the red, white, and yellow cables?
Aug 14, 2010 | Mitsubishi HS-U540 VHS VCR
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Is it digital? will I need a converter box?
May 13, 2009 | Mitsubishi HS-U446 VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Can't get a picture on TV screen
I think the tape is blank. I mean not recorded.
Oct 24, 2017 | Mitsubishi HS-U545 VHS VCR
Using the Misubishi HS-HD2000U
The connection "chain" that you need to have set up is as follows: First the source goes to the HD VCR, then that output goes to the TV...accordianman
Feb 13, 2008 | Mitsubishi HS-HD2000U VCR
Language setup for Mitsubishi HS-U510 VCR
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
The sound cuts on and off and on and off and...
First, have you definitely ruled out an external problem, by hooking it up to a different television or audio amp? If the problem follows the VCR to whatever it is hooked up to, then obviously, the VCR has a problem. Likely, this is an internal electronic defect. Services of a repair shop would be required. Sorry I can't be of more help.
May 05, 2007 | Mitsubishi HS-U795 S-VHS VCR
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
