Question about Birds
Bird identification by color black on top, rust in the middle and white on bottom
Slinteriors
  • 8617 Answers
SOURCE: Picture is bowed down from
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
Posted on May 07, 2008
SOURCE: 3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Posted on Nov 01, 2008
  • 157 Answers
SOURCE: strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Posted on Jun 16, 2009
Macs R We
  • 481 Answers
SOURCE: Aluminum G4 15
You can eliminate the graphics processor as the problem by attaching an external display or TV (using the required adapters) and seeing if the image there is OK. Frankly, it's much more probable that you have a display hardware problem, either a bad LVDS cable or a bad LCD display. If you're very lucky, the problem is just a loose connector at one end of the LVDS cable; otherwise, there is no way to determine which is the problem without trying both. The LVDS cable is relatively inexpensive compared to the display upper. The display upper is sufficiently expensive that repair on a unit this old, while perfectly possible, may not be cost-efficient.
Posted on Oct 28, 2009
Slinteriors
  • 8617 Answers
SOURCE: the screen like dips in the middle at the top and
Thats usually a convergence issue which requires replaceing both STK392-120 and also some of the 6.8 ohm 1watt resistors (6R8J1W) . You can get the convergence repair kit for that model ( DPTV305_DPTV345 & MAG01 Convergence kit) at www.tvrepairworld.com the kit contains the ICs all 12 resistors and the Cd with detailed repair instructions.
Posted on Jan 23, 2010
A black head small Australian bird with a white patch on both sides of its head with a red beak
check the bird identification pictures but it sould like a black head finch
Mar 10, 2017 | Cars & Trucks
Is there a bird that is all red except for the white breast?
Jan 04, 2014 | Birds
-1985 Porsche 911 took off door panels pulled the wires off the power window switches did not label them and now i don't know what color goes to what # connector on the switch
hello there
As you are looking at the switch ,the single connector should be on the top.
Top single conn. is linked with bottom left(red wire)
Bottom right -brown
middle left is blue with black strip
middle right blue with white stripe.
Sometimes this middle wires should be switched(left-right position), the are for window doing up and down.
Same goes for the front switch for pass window.
i hope this helps
Ivan
trubka
Nov 29, 2010 | Porsche 911 Cars & Trucks
Need of wiring diagram for driver's side window switches, or description of wires (colors) and placement on switches, on an 85 Carrera Thanks
Hello there
if you are replacing the switches the colors are as this
tho bottom conectors--red left-brown right-
The red is also goin to the t top connector
middle connectors --blue-black left--- blue-white right
top connector is only one and it is red (an extension from bottom red wire)
this should help you
trubka@yahoo.com
trubka
Oct 28, 2010 | 1984 Porsche 911
I have a Classic Coffee Concepts GB360 maker that needs switches
I have the same coffee maker which has a heater problem but the wiring is intact. The switches are wired like this:
Right Rear Warmer Switch: Top - White from other two switches
Middle: Black from other switches
Bottom: Red
Right Front Warmer Switch: Top: White shared with other two switches.
Middle: Black with connector to Black on other switches
Bottom: Blue
Lower Front Warmer Switch: Top: White from other switches and connector to white from inside.
Middle: Black and Purple together
Bottom: Black from inside and Purple from inside on a connector.
Jul 07, 2010 | Classic Coffee Concepts SSU50 Stainless...
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
I replaced the fwd / rev switch on my Club Car 1985
I recently replaced a F/R switch and just happened to write down which wires went where so maybe I can help. The front switch ( closest to front of cart) green/white wire to top contact, white/black to bottom.
Middle switch red/white to top, orange to bottom.
Rear switch green to top, black to middle and white to bottom.
Jul 27, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
I want to replace just the 3 wire receptacle head of my clothes dryer. there are three wires in the cord. white, black, green. i unscrewed the head and I dont know where which wire goes.
white and black are power green is ground the ground should be marked on the plug the black and white does not matter as long as the are on the power terminals they are across from each other the ground is by itself at bottom of plug W B
G
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
3 to 4 plug dryer
Not really sure what you are asking. But if you trying to hook the cord up... Green and white go to the middle terminal Then black or red to either side it doesnt matter which.
Jan 30, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
RADIO INSTALLING
there is a code for color!? ok, wait im searching...
found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires in your automobile. For example, if you have a British car the blue, blue and white , and blue and red wires are for the headlights. The red and white wires are for the instrument lights, and the green and white and green and red wires are for the turn lights. The color code simply identifies what that wire does. Could you imagine if all of the wires were the same color. You couldn't identify anything in a harness.
Jun 19, 2008 | 2001 Chevrolet Tahoe
Birds Logo
63 people viewed this question
Top Birds Experts
Tom Chichester
DaveMc3
DaveMc3
Heartland Ho
Level 1 Expert
Are you a Bird Expert? Answer questions, earn points and help others
