Question about TETRIX Remanufactured ClimbMax 150 Stepper -- Tectrix Refurbished-TECTRIX-150
Take apart the tetrix stepper to move it
Moving in small car
How will you track a moving image in the microscope?
Your question is hard to answer without more detail, including movement rate and required magnification. For relatively slow moving objects you can use a movable stage (X-Y stepper motors tied to a computer). Usually the direction of motion is erratic or unknown, and some digital tracking software will have to be written to drive the steppers so as to follow the designated object of interest. This may be something you have to develop yourself, although there may be some "tracking" software commercially available (or adaptable).
Note that you usually cannot take a video of the object as you track it, due to the quantum action of the stepper motors. However, this does not keep you from taking a series of stills (step - capture - step - capture - step ... etc.) and turning them back into a stop-action video. There are a lot of free or cheap programs out there to do that.
If the motion of the object is rapid, then you have a much bigger problem. One project I did some years back had this problem, and we could not actively track the sudden motion with a microscope. What we did instead was to reduce the microscope magnification, and significantly up the resolution of the high-speed camera (and yes, that was very expensive). At 1500 FPS, we could capture the object as it moved rapidly across the stage, then post-process the resulting frames to center on the object. The obvious limit here is that the object needs to cover a relatively small portion of the overall picture - which limits the magnification you can use. Of course, the offsetting advantage of this method is that you pay more for the camera, but don't have to have a movable stage on the scope.
Jun 19, 2017 | Science & Laboratory
Tip
How to choose a good area moving service
If you moving in San Francisco and need moving service-I can recomend you http://sfbayareamoving.com/ You can rely on SF Bay Area Moving, as a fully licensed and insured residential moving company and commercial mover to handle your belongings with care. Moving is our passion and we really care. Everyone who hires us, will receive a personalized friendly and reasonably priced professional service.
SF Bay Area Moving can move small studio apartments as well as large, multi-room luxury homes. We are also available to move your home office or business.
Home SF Bay Area Moving
on Apr 15, 2016 | United States Postal Service Moving &...
How do I get feeder t?o feed fabric when sewing
Check the feed dogs are in UP position. If so, are they moving back and forward when turning the hand wheel (be careful if you have a needle in the machine). If they are not moving back/forward, it is either the lower shaft has slipped out of position or the stepper motor has gone bad and needs replacing. Your local authorized husqvarnaviking dealer should be able to repair the machine. You can find the nearest dealer at http://www.husqvarnaviking.com/us
May 01, 2014 | Husqvarna Lily 540 and 550
2004 chevy trailblazer LS EXT. My gas gauge is not reading the gas amount and it keeps moving. Gas level can be at half and as I drive it drops but when I stop it moves back to half. Fill it up to where it...
This sounds like the fuel level sensor in the gas tank is going bad, or there is a bad ground at the tank. A technician using a scan tool can monitor the actual fuel level data to verify.
Another possibility is a bad stepper motor in the instrument panel, each gauge had a stepper motor to drive the needle.
Jul 14, 2012 | 2004 Chevrolet TrailBlazer
When it gets to rinse cycle it stops. I have to move it to finish it?
Possible that the program TIMER unit is faulty as it fails to move from the spot of rinse. Is this is a mechanical type timer the stepper motor / moving contact has failed to run and so stops at this point until it is assisted.
Try and remove power and use a WD40 to clean the drives, maybe reset the stepper motor on the timer unit or else you might need to replace.
It is possible to get one from a scrapped set to confirm and the cost will be reasonable.
Sep 17, 2011 | Washing Machines
What is the stepper motor
It's called the Idle Air Control motor (IAC). It is on the side of the throttle body. This controls the idle speed. What it does is let in a certain amount of air into the engine, in steps. The more it is open the higher the idle speed. The ECM controls it.
May 17, 2011 | 1996 BMW 318
Step motor error
One of the stepper motors has failed. The machine has two stepper motors: one that moves the needle back and forth and one that moves the feed. Take it to your dealer for an estimate.
Apr 02, 2009 | Elna Quilter's Dream 6003Q
Document feeder will not Operate
Try cleaning the rubber rollers onder the cover where the documents feed in, using a rag and some rubbing alcohol.
Jun 18, 2007 | Ricoh IS 330DC Flatbed Scanner
TETRIX Remanufactured ClimbMax 150 Stepper -- Tectrix Refurbished-TECTRIX-150 Logo
Top TETRIX Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a TETRIX Exercise and Fitnes Expert? Answer questions, earn points and help others
