Question about Brother CS6000i Computerized Sewing Machine
Needle is hitting feed plate - Brother CS6000i Computerized Sewing Machine
4 Suggested Answers
kent581
  • 87 Answers
SOURCE: The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Posted on Mar 18, 2009
SOURCE: brother ls 1217 - needle continuously hitting foot and plate and breaking
it sounds like the machine is out of time, & needs to be serviced
Posted on Feb 24, 2012
SOURCE: brother xr7700 needle hitting plate
sounds like the machine is out of time & needs to be serviced at a sewing machine repair shop
Posted on May 21, 2012
Feed dogs are hitting the needle plate
Needle is bent replace with new needle. You may need to adjust feed speed so that needle doesn't bend. Good luck
Jun 06, 2015 | Sewing Machines
The feed dogs are hitting the needle plate.
Sometimes it is just a bunch of lint built up under the needle plate between the feed dogs. Remove the needle plate (usually two screws) and clean out the lint.
Hope that helps!
Needle hitting stitch plate on my Viking Lilly 545 recently had it serviced, was sewing fine
try a new needle
if the needle is still hitting the needle plate, then it's possible that the machine is out of time and needs to be adjusted, or there is something wrong with the needle bar.
Nov 13, 2012 | Husqvarna Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Feb 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle breaking b/c it hits needle plate
Is the needle pushed all the way up into the shaft? It may have worked loose and slipped down a bit.
Nov 16, 2008 | Sewing Machines
Breaking needle
Sounds like the timing is off, have to take foot off, take plate off, put it in the zz position and using the hand wheel turn(with new needle in) and see where it is hitting feed dog, loosening the screws to the feed dog and moving it in the opposite direction out of the way so as not to hit. let me know how that works
Aug 08, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
20 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
