Question about Samsung La40c550 40" 1080p Lcd Full-hd Multisystem Tv
Samsung LCD LA40C550J1R no picture after some minutes
Picture fine but disappears after a couple of minutes. With no input the "connect signal cable" message appears and screen does not go blank.
SOURCE: Samsung HT-X40 System Problem
I've run across the same problem. For now I've run the optical cable directly from my cable box into my stereo and I'm good to go. I hope the update will be something I can download and use with my flashdrive since i'm not connected via a direct cable connection which I assume is how the update will be sent. I'm not sure if it will make it through my cable box.
Posted on Dec 09, 2007
SOURCE: Loss of Picture
You can use this firmware too:
http://www.samsung.com/us/support/download/supportDown.do?group=mp3audiovideo&type=hometheater&subtype=hometheatersystems&model_nm=HT-X40T&language=&cate_type=all&dType=D&mType=FM&vType=L&prd_ia_cd=03030100&disp_nm=HT-X40T
Posted on Jan 17, 2008
Luvlee
  • 59 Answers
SOURCE: Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Posted on Mar 23, 2008
lukster
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
blodwen
  • 8 Answers
SOURCE: u600 screen blank
Probably all due to a faulty flex cable that connects the screen to the main board.
I had simmilar problems so I replaced the cable and now the phone is fine.
Nick
Posted on Oct 16, 2008
How do I repair our Samsung LCD Television? I would really appreciate an answer ASAP. Where will my answer appear for my review.
Don't know what service provider you have, free to air, satellite, cable or what? Try feeding the TV another signal and see what it does. Play recorder movie from DVD, or if you have a VCR around even try that. If it plays the DVD etc, with no issues, then TV is not the problem, most likely the cable box, satellite box etc, could be as simple as a bad cable connection at the house, a splitter or street box. Eliminate all the simple things first, then look at the TV.
Mar 04, 2015 | Samsung Televison & Video
Samsung Ln52a650A1fxza lcd has a red tint when I turn it on. This red tint disappears usually disappears after about 10-30 minutes, then the T.V displays a normal picture. There are times when I turn the...
Check the LVDS cable !!! It is the cable that supplies the video signal from the main board to the LCD controller. If wiggling the cable clears up the problem or invokes the problem, you need a new LVDS cable!
Oct 18, 2013 | Samsung LN46A650 46 in. LCD HDTV
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
Sound no picture
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
Theinverter is the high voltage board that provides variable power to thebacklight lamp. This is the most common. When inverter is faulty youcan get no picture, or a very dim picture that can only be seen bypointing a torch light with a 45 degree angle on the LCD surface fromvery near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
Thisis quite uncommon, but happens. If the TV had been hit or moved the LCDcable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
Thisis the board that controls the video signal, it is difficult to test,as there is need to read determined values on IC pins. To test thisboard you need to purchase a service manual and follow thetroubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where youconnect the video and audio cables, if a signal board is defective,then you may get no picture on particular inputs located on faultyboard.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Jun 08, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
No signal
you have to take the remote, find the input button, push the input button untill your picture comes back, you should see the input go from cable/antenna, to vid 1--vid2---vid3---if pushing the button a couple of times dont change it, you will have to hit the input button, then arrow down, and select the nexy one, do that untill you find the picture
Jan 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
Samsung La40c550 40" 1080p Lcd Full-hd Multisystem Tv Logo
51 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
