Question about Nikon Coolpix L11 Digital Camera
Update firmware - Nikon Coolpix L11 Digital Camera
Playstation 3 won't load after apparent interruption during update.
Unplug and leave unplugged for 12 to 24 hours (i.e. ''overnight''). Do a search for a firmware update (not a ''regular'' data update). Download Firmware update and prepare as per instructions. Plug in Playstation, but don't try to ''load'' a game or anything. Perform the firmware update. If there are no firmware updates for it, attempt to install the same firmware as is current. You'll get a message that the firmware is up to date. Then exit the firmware installation, reboot the unit, and then try to load a game.
Jan 01, 2015 | Video Game Consoles & Games
Firmware version 370
I have searched all over Toshiba and different websites and it is not there. However it does look there they did release one some time ago. I think you will have to call Toshiba Tech Support Directly and ask them to either send you the disk with the Firmware or Upgrade It for you or maybe they could ever e-mail you the firmware. Here is there number.
Toshiba:- 1-855-383-7237
Feb 11, 2014 | Toshiba Office Equipment & Supplies
Firmware update
Click on the "Start" button and then type "Update" into the search box.
Click on "Windows Update" in the box that appears.
Click on "Check for updates" and wait for the updater to scan your system.
Click on the firmware update, if there is one.
If your DVD player's firmware is up-to-date on the right firmware, there will not be an update.
Click "Install Updates" if you have an update available to you and then click "Finish" when it is complete.
Restart your computer.
OSX
Click on the "Apple" button at the top of your Finder.
Click on the "Software Update" tab and wait for the computer to scan for any available updates.
Click on the "DVD Firmware Update" if it is available to you. .
Click "Install" and wait for the computer to install the update.
Restart your system.
Jul 03, 2013 | Computers & Internet
Sansa/Sandisk m240/1.GB Firmware information. I would like to be able to download firmware software for this device. If not a link for the older version of the firmware. Or maybe some suggestions for...
good day sir hope that this will help you to your problem....
What is a firmware, and what does a Sansa Firmware Updater do? Firmware defined
Firmware is the software code that powers your Sansa player. SanDisk actively and periodically updates the capabilities, functionality, and reliability of your Sansa player through this firmware. For optimal experience with your Sansa player, SanDisk recommends that you update your firmware with each new release.Firmware updates are free.
The Sansa Firmware Updater is an application designed to deliver the latest firmware, software support, User Manuals right to your desktop.
Download Sansa Firmware Updater.
Sansa players supported by the Sansa Firmware Updater:
- Sansa c200 series
- Sansa Clip / Clip+
- Sansa e200 series
- Sansa Express
- Sansa Fuze
- Sansa Fuze+
- Sansa View
Supported OS:
Windows 7, Windows Vista, Windows XP, Windows 2000 SP4
NOT supported:
Mac & Linux
NOTE: Administrative access is needed on your PC to run the Sansa Firmware Updater.
if this help you please rate me sir thanks you...
Jun 05, 2011 | Computers & Internet
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
Is it normal that when you r updating the firmware of it,much of time is needed?..the MB is increasing while updating
Usually firmware update takes much time depending on the speed of the Internet connection which you have.
First nokia updater have to be downloaded and when you try updating your mobile firmware then the nokia updator downloads the necessary update files from internet which takes again some time. After the firmware download then actual firmware updation happens. This will take some minutes.
Please note that interruption in firmware update may make your mobile unusable. Then you have to make a service call if anything happens like that. so perform firmware update with a high speed Internet connection and have UPS for your system.
I hope this is helpful to you.
Thanks
Mar 07, 2010 | Nokia N97 mini Smartphone
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Pic and vidos
I believe all you need to do is go to SanDisk's website, under Downloads, then download the Firmware Updater: http://www.sandisk.com/Retail/Default.aspx?CatID=1376
After installation of Sansa Firmware Updater
* Please make sure your Sansa player is in MSC mode before plugging it in.
* Plug in your Sansa player and it will automatically check for updates.
Common questions about the Sansa Updater
Q: What does the Sansa Firmware Updater do?
A: The Sansa Updater is an application that checks for the latest firmware updates then downloads and installs the firmware to your Sansa device. The Sansa Updater is NOT a firmware.
Q: Why do I need to install the Sansa Firmware Updater to download "firmwares"?
A: Once you install the Sansa Updater, you don't have to worry about which firmware to download for your device. Sansa Updater downloads and installs the right firmware for your Sansa device.
Q: Do I need to install the Sansa Firmware Updater everytime there's a new firmware?
A: No, once the Sansa Firmware Updater is installed, future firmware updates are done by just plugging in your device.
Q: What does a "firmware" do?
A: Firmwares contain miscelleneous bug fixes and enhancements.
Q: Which Sansa players is the Sansa Updater compatible with?
A: The e200, c200 and m200 series
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
Q: How to check for firmware version?:
A: On the e200 and c200, press "menu" and go to "Settings" then "Info"/ "System Info". For m200, press "menu" then "Information".
Nov 12, 2008 | SanDisk Sansa e260 MP3 Player
Nikon Coolpix L11 Digital Camera Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
