Question about Roper RAX4232KQ Top Load Washer
Lid locking switch issue?
Turn it on, the water starts for a short time and then the lid locking device starts clicking on and off and shuts down the washer. Do I need to replace the switch or could it be something else?
catriver
  • 878 Answers
SOURCE: Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Posted on Nov 08, 2006
catriver
  • 878 Answers
SOURCE: How to get the top off the washer
Jenlyn. The whole cabinet will lift off. Remove the two screws behind each end of the top consol. Pull forward and lift up. Remove the snap springs and lid switch harness and pull the cabinet forward and off...see the attachments...Catriver..post back.
Posted on Feb 01, 2007
  • 112 Answers
SOURCE: roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Posted on Nov 08, 2008
landsend
  • 1066 Answers
SOURCE: How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Posted on Mar 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: Need to replace safety switch for top lid. How to
Welcome to FixYa.
Here`s a helpful link for changing it out, and it covers most whirlpool built washers including Roper and removing the screws...locating them can be tricky on some models...this helps.
http://videos.wittysparks.com/id/3098139337
If this gives you any trouble I will try to help in any manner I can of course, let me know. Good luck.
Regards,
Macmarkus :)
Posted on Jun 09, 2011
May tag centennial lid won't lock to start cycle
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Jan 03, 2017 | Washing Machines
Why won't the control lock light turn off?
Jun 11, 2015 | Washing Machines
The lock keeps locking and turning the washer off
May 30, 2015 | Whirlpool Inglis IP4400 Washer
I turn my machine on the lock light is on plus the drum clean & cottons lights are on, try to turn the lock off &bit won't.Perhaps it needs a drum clean but nothing will work
May 25, 2015 | Fisher and Paykel Washing Machines
What is wrong with a washer that fills up with water lid lock clicks but will not do anything else just clicks?
May 14, 2015 | Whirlpool WTW4800XQ Washer
I HAVE REPLACE THE DOOR LATCH AND MASTER CONTROL. I AM STILL GETTING CLICKING
Apr 17, 2015 | Washing Machines
Work around lock lid
Apr 03, 2015 | Amana Washing Machines
There is a key symbol above the digital time display thing and the door e not lock, just keeps bleeping. Why
perhaps a lid lock problem
Mar 26, 2015 | Washing Machines
Maytag LSG washer lid won't lock to start
Mar 10, 2015 | Maytag Washing Machines
Ge washer gcrh410
May 19, 2014 | Frigidaire Washing Machines
Roper RAX4232KQ Top Load Washer Logo
18 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
