Question about HP Pavilion m7760n PC Desktop
Hard Drive Replacement
The hard drive in my m7760n is failing. I tried to replace it with another SATA drive. After physically removed the old drive and replacing it with the new one, the BIOS still calls out the old drive as the first drive (primary) and the new drive is recognized as the third (the DVD being the second). How do I make the new drive into the primary? FYI, BIOS version - Phoenix Award v5.08.
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Posted on Sep 28, 2008
SOURCE: computer doesn't see new secondary hard drive
There is no option in the bios to enable sata. It appears that the sata ports are just for decoration (hence hp using IDE)
Posted on May 29, 2010
SOURCE: HP 6200 Windows 7 OS
did you move the pin of the second ahrd drive to "slave" ?
Posted on Aug 03, 2011
HD REPLACEMENT
Check if you can use SATA else you'll have to look for IDE
Actually to insert a SATA drive is easier then replace a light-bulc.
Just remove cables, unscrew from "drawer" insrtn new drive, scress, replace cables.
If it's a system disk, the difficulty is resintall your system. After you've replaced Hard disk, formulate your question with more doubts
See some fine videos here
How to install SATA hard drive into computer
How To Install Internal Sata Hard Drive and Activate In Windows OS
How to install and remove SATA Hard Drive
How to Replace Desktop Hard Drive
How to Install Second SATA Hard Drive
Jun 27, 2015 | Computers & Internet
How do i replace and set up a new hard drive
Physical replacement is not hard. Just make sure you buy the correct new hard drive - sata/ide. Connect it the same way the older drive was connected. 1 connector for power, 1 connector for communication, nowadays usually sata. And you're done. After that it's operating system installation time. Most likely from a dvd/cd-rom drive. Most of operating systems now install quite easy next/next/next/default/licence key/next/next... I do suggest you get someone to help you install operating system anyway.
Aug 24, 2014 | Dell Studio Xps 8100 Desktop Computer
My Toshiba Satellite A215 starts to boot but the hard drive never spins up. The screen remains black and it never goes into POST. I took the battery out and tried to run without; reseated the hard drive,...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 21, 2011 | Toshiba Computers & Internet
Computer doesn't boot 'no boot device available" it cant find the hardrive it says sata 0-none sata 1-none sata 3-none sata...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 17, 2011 | Dell (Y3392) 80 GB SATA Hard Drive
Doesnt read at all. Tries to start to turn but fails
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
hope this helps
Jan 25, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My Samsung 250 GB portable HDD is not recognised now. It was working for last 2 years without any problem. Recently I found my PC infected by "WIN32" & Torjan viruses. It may be the reason. But I tried...
Try connecting it to another computer.
If it does not work, then either the disk-drive has failed,
or the USB-cable is damaged,
or the USB-to-disk-drive interface inside the case has failed.
Is the SAMSUNG still under warranty? (1 year? 2 years? 3 years?)
If so, SAMSUNG will replace it, at minimal cost to you.
Sep 25, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Replacement drive for HP DV5000
As per HP, the maximum capacity of Hard Drive shipped with dv5000 series Notebook is 100 GB 5400 RPM SATA Hard Drive.
The Specifications of the Hard Drive compatible with your Notebook are SATA 5,400RPM, 2.5in width, 9.5mm height.
However, you can install a maximum of 160 GB SATA Hard Drive in your Notebook.
You can purchase the reqired Hard Drive for your Notebook from the link below :
http://bixnet.com/12insanohadr.html
Find the requied instructions to remove and replace the Hard Drive in the Notebook from the Manual of the Link below :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Please go through page number 98 of 260 in the Manual to find the required instructions.
Hope this helps....
Nov 29, 2008 | HP Pavilion dv4000 Notebook
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
My computer stopped detecting my hard drive
Hi, Based on your post/description: 1. Tried on 3 different computers - no go, so it's not a PC problem; 2. Tried replacing the cable - no go, so it's not an interface problem; 3. That leaves you only with the Firelite itself. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct to a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 03, 2007 | SmartDisk FireLite 40 GB Hard Drive
New Maxtor 3200
Hi, This is a common problem with external storage. Based on your post/description: 1. Your laptop does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the PS3200 itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it directly inside a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 02, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
HP Pavilion m7760n PC Desktop Logo
23 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
