Hotpoint aq9d692u Drum knocking in spin cycle
4 Suggested Answers
  • 1294 Answers
SOURCE: hotpoint aquarius 1000 deluxe
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
Plug off the wall, & check your outlet filter first.
Posted on Nov 26, 2007
  • 3 Answers
SOURCE: WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
Posted on Jan 14, 2008
  • 139 Answers
SOURCE: Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Posted on Jan 15, 2008
Hotpoint aq9d692u
This is classic. You need to replace drum bearings.
Only a Certified Technical Engineer should do this work.
Apr 11, 2014 | Hotpoint Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
Hotpoint aquaries wf321 is making a loud clicking/knocking noise when its in the spin cycle, to me sounds like a poss bearing gone or maybe something is caught up?
From the front of the washer, spin the drum by hand, if it feels rough or is noisy or rumbling, then the drum bearings have failed.
It is possible that there is something caught between the inner and outer drum.
Nov 30, 2010 | Hotpoint Washing Machines
It sounds like a jet is taking off when it is going through the spin cycle
the drive belt can make this noise also the bearings on the drum but they more often rumbe at first, just before they start to brake up they realy do start to make a lot of noise, there very pricey to replace as well
try opening the door and lifting the inside drum with your hand if there is any lift and it knocks when lifted lightly its the bearings on there way out, also spin the drum by hand if it grumbles when spun its going to be pricey
Oct 19, 2009 | Hotpoint WMA54 Front Load Washer
Out of balance spin
next time its empty open the door take the metal drum and test for any movement if you hear/feel a knocking the drum bairings need replaced, makes it spin if centre
Oct 04, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
