Question about Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher
Dishwasher not working
The light is on, the timer is working but the washing cycle does't start
SOURCE: dishwasher won't start rinse cycle
if the water is switching off at the correct level to initiate the wash cycle and assuming that the water is not being pumped out continuously after that, i would say you have an electronic control problem. there should not be any changes taking place on the display when opening the door
Posted on Aug 15, 2007
abhishek33
  • 1239 Answers
SOURCE: Electronic Timer sticks on Wash Cycle
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Nov 10, 2008
  • 177 Answers
SOURCE: dishwasher starts but never seems to come out of wash cycle
Check to see if the unit is heating. Open the door mid cycle. If the unit doesn't heat then the unit cannot advance to the next step in the programme. it is basically waiting to reach temperature which it won't if the heating element or thermostat has blown. Hope this helps.
Posted on Jan 19, 2010
  • 457 Answers
SOURCE: Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Posted on Feb 28, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Timer light on front panel of dishwasher has stopped working--how is it replaced?
Most of the led lights are fused to the circuit board. Sounds like the circuit board is going or gone bad. I'm not sure because you did not give the model of the dishwasher.
Most of the control lights are led and do not go bad. But the circuit board that controls the lights can go bad. You may be able to fix the control circuit board but replacing it would be easier.
Oct 14, 2014 | Maytag Dishwashers
Why won't it run
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic board.91d0c2b1-1baa-49b9-9f99-f6a86f3b29df.jpg
Sep 29, 2013 | Frigidaire Gallery FGBD2451KB Full Console...
Panel lights shut off when door closed. Have to set before shutting door is this normal?
Hello Pat Braley - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Dec 08, 2012 | Frigidaire Professional Series 24 in....
Kenmore 13742k603 wash cycle lights come on but wash will not light and start
see the diagram attached:
1) test the switch door for defective or open, if there are wrong the relais will not close and NOT start the motor.2) Timer test, 3) c.breaker from you home or blown fuse 4) wires defective loose, burn, or break
Jun 18, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Only can use the heavy wash cycle
HELLO THERE
The cycle doesn't advance or you are unable to use one of the cycles such as light or the normal wash cycle, your problem normally is caused by a bad timer It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance.and if you set it to the normal cycle or light cycle and nothing happens Then you need to replace the timer. ok? hope this is veery helpful for you
Best regards Michael
Jun 05, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Certain cycles do not operate
YOU JUST NEED TO REPLACE YOUR TIMER NOT AS EXPENSIVE AS A NEW DISHWASHER
Nov 08, 2006 | Frigidaire 24 in. PLD2850 Built-in...
Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Logo
37 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
