Question about DeLonghi DCR902T Coffee Maker
Delonghi bco330t power button blinking - DeLonghi DCR902T Coffee Maker
Can't turn off blinking pump button. Do not want to use pump at all.
Sounds like an intermittent pump control button, keep trying and you might get it to switch. You could also try disconnecting entirely from power for a few hours, then plugging it in. I think that the humidifier power-up default is with the pump disabled.
Jul 24, 2014 | DeLonghi DE500P Dehumidifier
Delonghi BCO330T won't heat or brew on coffee or expresso side. Burner won't heat but power is getting to the machine. 17 months old, out of warranty.
Delonghi BCO330T, this is my third one and it has the same failure. It is a know problem and the answer is they don't care
Apr 06, 2014 | De'Longhi BCO330T Combination Steam...
Nespresso descaling
Make sure the machine is ON and you have power, then proceed as per instructions.
Jan 12, 2014 | DeLonghi Coffee Makers & Espresso Machines
How do I reset my delonghi ec860
my coffee machine is not working,,, the water ligh is blinking green n not doing anything.. anyone can help with this?
May 18, 2012 | DeLonghi EC Coffee Makers & Espresso...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Oct 23, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
Mar 21, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi DCR902T Coffee Maker Logo
83 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
