Question about Kenmore 59962 / 59964 / 59969 (25.5 cu. ft.) Side by Side Refrigerator
Where is the fuse for kenmore 795.7830 refrigerator
No power to unit
Does anyone know if there is a fuse in the Kenmore freezer/refrigerator, model no. 596.6998?
Refrigerators generally have no fuses. However, Units with electronic control panels may have one
What is wrong with unit? Details please? What is happening?.
Jan 11, 2017 | Kenmore Refrigerators
Kenmore 52649 side by side
try unpluging it for about 5 mins. Sounds as if it might need to recharge the coolent, Possibly during the surge might have blown an internal fuse. Contact the manufacturer. Curently their site is down.
Nov 14, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Is there a reset button or internal circuit breaker on sears refridgerator model # 795,7830
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There is not internal circuit breaker or fuse in a refrigerator.
Component failure acts as the fuse.
There is a reset button on the control panel of your refrigerator.
It is a small black button. Located near where the part number is shown on the board. This is rarely the solution to a problem.
You may try to unplug your refrigerator for 30 minutes and reboot your refrigerator.
In your owners manual, it is recommended to install a surge protector. They are a good investment for $20-25.00. Static electricity, the slightest change in voltage and a magnetic field will knock out a electrical control board.
If you elect to press the control board reset button make sure you ground yourself by rubbing your hands on something that is steel.
25134658-bkvywf5rc1reqors4q4ptmqv-4-0.jpg 25134658-bkvywf5rc1reqors4q4ptmqv-4-3.jpg
Sep 24, 2014 | GE Refridgerator Relay Overload Wr07x10011
Kenmore refrigerator model 795.78312.800 not working no display
If you have no lights on the inside of the unit and no display first verify you have power to that outlet. If you have power to the unit then you have a blown fuse on the main board. Part number: EBR41531305 The main board is on the back of the unit.
Mar 14, 2013 | Refrigerators
Kenmore 79558813900 refrigerator has no power - no lights, fan, etc. Outlet is fine.
The cable that powers the top drawer might be severed. The cable runs inside left panel to drawer on left side as well. That happened to our unit. We had the same problem. In which case you need to replace the power cable.
Dec 29, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore 795.5881 side by side refrigerator and I came home this afternoon and it has lost all power, no lights or anything. No breakers had tripped and the receptacle will power other items.
i had same problem, no compressor no lights nothing. power was good at outlet. took cover off top of unit. noticed a blown glass 15 amp fuse. cost less than 30 cents to fix
Sep 05, 2011 | Kenmore 59962 / 59964 / 59969 (25.5 cu....
My kenmore sid by side frige has lost all power the recepticle i use is fine.it's less than 2 yrs.old
Reset the circuit breaker or fuse and ensure the fuse has a 15 amp time-delay to provide enough power to the refrigerator.
Ensure the temperature control knob is turned past "0" and is set at a temperature cool enough to require motor function from the refrigerator.
Wait 20 minutes and check the power on the refrigerator again, as the unit may be in a defrost cycle, which may make it seem as if it was turned off.
if that doesn't work, and your sure you have power to the plug itself,, contact the searsdirect.com
they have an online chat repair
Jun 12, 2011 | Kenmore Side by Side Refrigerator
My VERY OLD side by side Kenmore refrigerator is running, but not cold. Could it be a fuse?
It seems that the gas, feron, has leaked from the unit. This is what cools the unit. It needs to be refilled. Please get in touch with the fridge service people.
May 23, 2011 | Kenmore Refrigerators
No power to the side by side refrigerator
replacing the mother board is the option that a repair person uses if they are authorized on the back of the unit there is a square plate remove it and you will see the mother board. on the bottom right of the mother board is the culprit fuse. its soldered in. you will have to go to an electronic store and get another fuse and either replace it or have them replace it for you. i went to radio shack and picked up the fuse holder, soldered it in and in the future will only need to replace fuse.
Good luck..............
Jul 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore 59962 / 59964 / 59969 (25.5 cu. ft.) Side by Side Refrigerator Logo
135 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
