Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
Under kitchen sink smells like moth balls
Our kitchen sink area under the cabinets smells like moth balls. The actual drain and garbage disposal doesn't smell, the smell comes from under the sink. Help!
2 Suggested Answers
  • 2344 Answers
SOURCE: how to unstop kitchen sink with disposal. I have a septic system. water goes down one side and up the other side.
Yes. I am familiar with these.
You or someone will be needing to take a large bucket or some pans and put them under the sink and undo all the pipes and the drains and the garbage disposal.
You will find a plugged up pipe.
I have already unplugged my daughter's about 10 times in the last 10 years.
Usually, the problem is she has put something down the sink she shouldn't have.
Example: Egg shells. Will not wash down. Rough silage: Clogs pipes.
When you get it apart, you will likely identify the product causing the problem.
God bless your efforts.
Posted on Jan 12, 2016
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
I bought a new kitchen sink and pipes with a garbage disposal. Over night the smell in the garbage disposal is like rotten eggs! How can I make it smell good?
Use hydrogen peroxide and/ white vinegar to safely deodorize disposal.
Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Swanstone KSLS-3322 Double Bowl Kitchen...
Newer Maytag dishwasher smells really bad inside
This problem can normally be fixed very simply and you can do it yourself.
1. There is a flexible drain line that goes from dishwasher to the sink drain line or garbage disposer.
2 You will find this flexible drain underneath the kitchen sink.
3. Make sure that the flexible dishwasher drain line goes up above the sinks lower portion of the sink basin and then comes back down into the sinks drain line or grabage disposer. The dishwasher flexible drain line must go above the bottom of sink basin like an upside down u shape, it will act as a upside down p-trap that you see under the sink in the sink drainline.
4. Once you have the flexible dishwasher drain line in this configuration (upside down U shape or p-trap) it will prevent air from leaking out of the dishwasher as the smell you are smelling is coming from the drian line.
5. You should also look inside the bottom of dishwasherr to make sure the drain screen is not clogged up.
Sep 08, 2011 | Dishwashers
The dishwasher just stopt emptieing top first then bottom
This could be due to a block in the kitchen drain.
Have you checked if there is no garbage disposal unit in sink which has not been turned on.
Alternatively, take the drain hose from under the sink plumbing and drain straight into the the sink with some support. But this may be hard if the dishwasher is built into the cabinet.
Nov 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Can you install a garbage disposal in a corner undermount sink
Are we concerned about the distance between the bottom of the sink and the bottom of the cabinet?
I have installed a lot of disposals on under-mount sinks and I have found the the Badger company has a 1/3 hp unit that is quite short. It may seem a bit small but we need to remember that disposals are not made to chop wood.......1/3 is plenty strong for a person who uses their head when shoving food sown it. Their 1/2 hp unit might also work.
They are available at Lowes and Home Depot for around $60.
Hope this helps
Apr 26, 2009 | Jacuzzi Kitchen Iron Black Finish...
Foul odor coming from kitchen sink/dishwasher area????
Hi Jenny - I had a terrible smell coming from under my sink, and I too thought it was a dishwasher/garbage disposal drainage issue. I used vinegar, baking soda, bleach and hot water on a daily basis. When I cut out the wallboard from under the sink and the smell got even worse, however, there was no sign of any water leaks or evidence of a dead animals. Come to find out, when I had a "friend" cut out a pass through from my kitchen (above the sink) into the den, he cut the pvc exhaust pipe and didn't re-route it nor cap allowing the fumes to escape outside via the attic. Thus, the fumes had no place to go other than down. The smell confused me because I thought it was rotten food or most likely a dead mouse trapped between the wall. The smell was actually causing me to get headaches. It's been almost 24 hours that this was repaired and I already can "smell" the difference. I hope this helps! Good luck.
Mar 30, 2009 | Tappan MDB531RF Dishwasher
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bad smell
It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Please rate this solution.
May 18, 2007 | Bosch 24 in. SHU6802UC / SHU6806UC...
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
377 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
