When i turnit on, and when i press search, the scanner says "all channels loched out
You are pressing the "scan" button in the upper left hand position and getting all channels locked out? Correct?
If
you haven't programmed any frequencies the channels will stay locked
out. Get your local frequencies by doing a search for police scanner
frequencies. Once you have gotten the information for your area press
the "PGM" button on the lower right hand side of the key pad. Input
your 1st frequency ###.#### then press "ENTER". Press "PGM"key again
and enter your 2nd frequency then "ENTER" again. Repeat as often as you
wish to enter more frequencies.
Make sure you are entering your frequencies in empty channels unless you want to over write one that you don't want to use any longer. Press "PGM" until you get to an empty channel.
When you are done, (you can stop
any time) press the "SCAN" button in the upper left hand position and
you are in business. You are supposed to be able to choose which memory
position you wish to use but I haven't tried to figure that one out.
If you need the manual for the radio go to radioshack site and do a search for PRO95 and it will come up in PDF format.
Hope
this helps. I have owned the pro 95 for maybe 6 or 7 years and after
doing a little programming yesterday the thing is much more to my
liking. It scanns quicker and scans the channels I wish to listen to.
