Question about Whirlpool 3.6 cu. ft. Traditional Top Load Washer with H2Low wash system
Whirlpool 3.6 cu. ft. Traditional Top Load Washer with H2Low wash system Not drawing hot water. Valve is on for sure
  • 1314 Answers
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Posted on Jan 10, 2008
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
  • 10865 Answers
SOURCE: What cu. ft. size is my Whirlpool top loading
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Posted on Jul 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: My whirlpool 3.2 cu ft washer is making a loud
screw%20removal.jpgUse a screwdriver to remove the screws holding down the control panel,then swing it upwards.
Use a flat blade screwdriver to pop these Clips
Unplug the lid switch connection.
Tip the case forward and remove it.You will now be able to repair the washer! tip%20the%20cabinet%20forward.jpg" />
Posted on Oct 23, 2009
Testimonial: "Thank you so much, hopefully we can quiet this baby down."
  • 154 Answers
SOURCE: whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Posted on Oct 27, 2009
Remove towel from under agitator
work agitator back and forth while pulling n towel is all I can tell you .
Mar 05, 2015 | Whirlpool 3.6 cu. ft. Traditional Top Load...
No cold water goes into the washer
this sounds like a water valve fault. if you put the cold water on to hot valve & set to hot wash does it fill. if so it is a faulty valve.
Jun 16, 2013 | Amana 3.2 cu. ft. Top-Load Washer
LF COMES ON MY FRONT LOADER LED SCREEN
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Here is the valve to order in case it is faulty.
Nov 09, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Fuse
Make sure the breaker is not tripped, make sure you have 120 volts at the plug outlet. make sure you water hot and cold water valves are open. sounds like to me your the fill valve is bad ( thats where your hoses hook to the washer) try to wash a load in cold water only then try hot water only. if you have power most likely its your fill vale
Aug 17, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer has stopped filling. I have checked all the suggested reasons and none of them are the issue.
there are only 4 total reasons for this fault 1 your water has been turned of. 2 the lid switch is faulty 3 the most common the water inlet valve is burnt out 4 there is no power signal getting to the water inlet valve try putting the cold water hose onto the hot water inlet switch the washer to hot wash see if the water comes through
let me know
Dec 29, 2010 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a Kenmore/Whirlpool Washing machine model 110.26832691 that doesn't allow hot water into the tub. I have put a new timer as well as a new temperature switch. Any answer?
Hello
Please try to swap both the connections, hot to cold and cold to hot, swapping will hopefully work. If swapping wont work then the water inlet valve also known as inlet hose assembly is bad and needs replacement. Please check the water level switch as well although I believe it is the water inlet valve causing this problem.
Kevin
Nov 11, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool 3.6 cu. ft. Traditional Top Load Washer with H2Low wash system Logo
13 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
