This error appears in my Incredimail program how do I resolveException: General Unhandled Exception (C015000F)Faulting Offset: 00084671Module: ntdll.dll00084671 ntdll.dll00015424 kernel32.dll0
The two area I am have problems with are with my Internet Explorer 11 64 bit and my Incredimail program.My O/S is Windows 7 ultimate 64 bit and I have several browsers ,Opera,64bit, FireFox 64bit,Chrome 64 bit,Internet Explorer 11 64 bit Everything works great with the exception of my Incredimail program I get this error "Exception: General Unhandled Exception (C015000F) Faulting Offset: 00084671 Module: ntdll.dll 00084671 ntdll.dll 00015424 kernel32.dll 00036CE1 MFC80U.DLL 00032270 MFC80U.DLL 000321C6 MFC80U.DLL And in my Internet Explorer 11 I get this error cannot open web pages . Thank you I look forwar to your response
  • Cyndi Praegitzer
    Cyndi Praegitzer Apr 03, 2015
    I have the exact same thing, what did you do to fix it. The first Crash I got was Access_violation (C00000005) on reading from 04967F1A etc... with (8)ntdll.dll listed. I removed the facebook totally from Incredimail and it solved that problem, but before I done that I was made a big mistake and downloaded 2.5 and got a new error message, uninstalled 2.5, but still get this error. I did try running with mode for windows xp service pack 3 and it worked for a while, now it is back. Help
SOURCE: How can I fix this problem?
My printer is only a few months old. I have used up all the label roll that came with the machine and have put in a new roll (99010) which is slightly slimmer than the original one. I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label). HELP!
Posted on Oct 09, 2008
echelon09
  • 23 Answers
SOURCE: windows explorer has stopped working
There is probably a problem with one of the add-ons that the browser runs. Go to the internet options and "manage add-ons." Disable anything that looks suspicious.
Posted on May 14, 2009
  • 130 Answers
SOURCE: This is the error message
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Posted on Jun 16, 2009
  • 13 Answers
SOURCE: hp 4288 all in in one scaner is not working
Suggest the following
1) if not installed - install service pack 2 for vista - remove and reinstall HP software.
2) remove any software for Kodak digital Cameras (found by Googling and may not work)
3) Contact HP ;-)
Posted on Jul 07, 2009
  • 5 Answers
SOURCE: aioc.exe has stopped working lexmark 5400
this usually happens when you try using the old cd on a vista os.. most of the time the cd was made to work on xp only since during the time of release of those printer, vista was not yet out of the market.. try downloading this patch ftp://ftp.lexmark.com/driver/inkjet_drivers/AIOCenter_patch
disable user account control first.. you can do this in msconfig on the tools tab then run the patch
chose the right series of you printer.. normally when you run the file it will extract the file and run the patch.. cancel the application after extracting the file..
go to c drive on you computer... look for the folder LxkPatchAIOC
go inside the folder and look for the word aioreg.. right click on it and choose merge...
that should fix the issue..
if in case it didnt work on you... try calling 1-800-lexmark
you can email me at zuki_kishimo@yahoo.com for more questions about lexmark
Posted on Aug 30, 2009
Black screen Faulting module path: C:\Windows\WinSxS\amd64_microsoft.vc80
If Explorer is corrupt then most of its support will not load, hence the long list of errors. Can you press F8 just before boot and choose "repair" from the options menu? That may repair the main kernel.
Dec 04, 2013 | Computers & Internet
Stackhash fd00 appcrash
Looks like a corrupted exe file try to solve it with scandisk and if it doesnt help try to reinstall the app.
Nov 28, 2013 | Computers & Internet
Fuji FinePixViewer booting error.
Your operating system is probably outdated for the firmware of the device you are trying to connect. Upgrade.
Dec 21, 2012 | Fujifilm Finepix A900, A825, A820, A610...
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
Windows 7 64bit ultimate edition Lots of ''Application Error''
asus M2N68-AM PLUS motherboard is supports all operating system but intel is not support win 7 64bit
May 13, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
Keep getting following error in Outlook 2007:
Fault bucket errors can be caused by many things. Sometimes it is a program that is using memory improperly. Also, it can be a hardware issue with the RAM itself.
You can Google RAM TEST and find programs that will test your RAM. MS makes one that you make a boot disk and run it.
Also, it never hurts to open your computer and make sure the RAM is seated properly. The last time I saw many random bucket errors it turned out to be 2 of 3 RAM sticks weren't properly seated.
May 04, 2010 | Dell XPS M1330 Laptop
Unhandling error
How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Question : How do I correct an "Unhandled Exception" error received while editing a scan from my all-in-one printer? Answer : To correct an Unhandled Exception error received while editing a scan:
  1. Open the Control Panel on your computer and double-click Display.
  2. From the Display Properties window, click the Settings tab, and then the Advanced button.
  3. From the "DPI setting" drop-down list, select Normal size (96 DPI).
  4. Click OK and close all open windows.
  5. Restart your computer for the changes to take effect.
May 04, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
An unhandled win32 exception occured in svchost
Windows error from some component of your browser most likely. Try reinstalling the web browser (and rebooting if it's Internet Explorer).
Apr 07, 2009 | Computers & Internet
459 people viewed this question
jasbo
jasbo
