Question about Datalogic Memor Smartphone
How to recognize two devices at the same time on activesync ?
I've created an application witch read data from xml file on datalogic memor device and i want to connect 2 devices at the same time but activesync recognize only the first one ! I do not use syncronization ! but only my app to send data on the server.
MC9190 WLAN Problem
To permanently disable the Suspend Mode on a MC9190:
On your PC, create an empty text file, then type the 2 following lines:
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"BattSuspendTimeout" = dword:00000000
Save the file, then change the extension to ".reg". This changes the text file into a registry file.
Copy the registry file in the /Application folder of the scanner gun. Cold boot the device. Your MC9190 will no longer go to sleep mode, or "suspend mode".
To automatically enable the Wireless antenna at startup, create another registry file, then type the 2 following lines:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\WLAN]
"InitialState"=dword:00000000
Save the file, and copy it into the /Application folder of the scanner gun. Cold boot the device.
Feb 12, 2013 | Motorola MC9190-GST
I have an HTC 8925 and when I turn it on, it turns on but it doesn't fully load. The only thing it shows is the ATandT logo on a white background. It does not make any sound or beep or anything in that...
Thanks for visiting FixYa!
From your explanation, it sounds like you've downloaded an app or program that has a driver conflict with the phone's operating system. You may need to flash your phone's ROM (operating system) with a new updated version to get it to work properly again. Since you didn't include who your cellular carrier is, I'm going to assume that it is AT&T. If the phone is not an AT&T Branded phone, disregard these instructions.
This phone is also called the HTC Tilt 2 (AT&T) and there is a new ROM download for the phone which should solve your problem. You'll need to follow the directions EXACTLY to flash your phone's ROM - and I do mean exactly!
This software update is intended for the HTC Tilt 2 for AT&T only and users should not load or attempt to load this version on any other device as it may cause serious issues/damage.
Please note that during the update process, the device will be Hard Reset and anything that is NOT part of the Operating System (contacts, calendar, music, etc) will be permanently deleted; always make a point of backing up your device's data on a regular basis!
Before you proceed, please confirm that this software upgrade is a newer version than what is currently loaded on your device. If it is the same version and your device is operating normally, there is no need to reload the software.
To determine the software version running on your device, go to Start > Settings > System Folder > Device Information > Software Information.
Validate that the ROM version is 2.10.502.4 if it is not, you will need to update the software on you device.
Before you run the ROM Upgrade Utility (RUU), make sure you check and do the following first:
  • USB sync cable is connected to your device and PC to establish a connection with Activesync/Windows Mobile Device Center. If you don't have ActiveSync installed on your PC already, the CD found inside your handset box can be used to install the application. If you lost the disk, please go to www.microsoft.com >Downloads & Trials> Windows Mobile Downloads and download the appropriate application (ActiveSync or Windows Mobile Device Center) depending on your PC's OS. You will also need Outlook or Outlook express installed in order to backup your contacts, calendars, e-mail, tasks etc.
  • Remove your storage card prior to running the upgrade. Do not put it back into your phone until after the upgrade process is complete.
  • The standby and hibernation modes are disabled on the computer.
  • All running applications on the computer have been closed.
  • Ensure that you device has a battery level of at least 50% (Start > Settings > System Folder > Power > Battery) If the battery "dies" during the upgrade process, there is a chance that the device will not recover and will need to be sent to HTC for repair.
  • The update can take several minutes so set aside time when you will not be interrupted.
  • Do Not interrupt the upgrade process or press any buttons on the device until the process has been completed (the device will reset itself when the update is done).
  • Warning: Installing this update will erase all data stored on the device, restoring your device to the factory default settings. Please be sure to back up any important files to preserve your data.
General Procedure on Installing the ROM Update
  1. Back up your personal data from the Mobile Device to your computer using ActiveSync (Windows XP or sooner)/Windows Mobile Device Center (Windows Vista and Windows 7) or a 3rd party backup utility if you want to ensure you don't lose any of your data.
    • If using a 3rd party backup utility, be sure that you are not backing up the Registry as this will cause issues once restored to the device after the update.
    • You will need to reload any 3rd party applications manually. Once you have created your backup file, be sure to copy the backup file to a storage card (ensure that Storage Card Encryption has been disabled on the device if you have enabled it) or to your PC before proceeding with the ROM update.
  2. On your computer, click on the Download link (below) and save the file to your desktop.
  3. Establish a connection between ActiveSync/Windows Mobile Device Center and your device using the provided USB Data cable.
  4. Locate the ROM file (the one you saved in step 2 above) on your PC and double-click on the file to run the ROM Update Utility (RUU) to install the ROM update to your Mobile Device.
  5. Follow the RUU Wizard prompts. When presented with the readme screen, please read the Readme since it provides a lot of valuable information on the upgrade process and what you can expect during the upgrade process. Check the box beside the "I understand the caution indicated above and has reviewed the Readme" and then press Next to continue. The remaining steps will typically involve checking the check box and pressing the Next or Upgrade button until the upgrade is completed.
  6. Restore your personal data back to your Mobile Device using ActiveSync/Windows Mobile Device Center or the 3rd party backup utility you selected.
Click here:
HTC Tilt 2 (AT&T) ROM Update 2.10.502.4 ' 08.30.2010 then click on: Download when you get to the HTC Downloads page to download the ROM to your PC. Then begin the install.
Apr 07, 2011 | Cell Phones
JUST GOT A NEW COMPUTOR, WE HAVE DOWN LOADED THE SKYPE PROGRAM BUT HAVE LITTLE VOLUME. ANY SUGGESTIONS?
Here is the fix:
First:
SKYPE-->Tools-->Options-->Sound Devices-->(untick) Enable Automating Sound Device Adjustment Settings-->Save.
Then
You need to select "show hidden files" in folder options
Use any editor like Word Pad or Word, as config.xml is a real text file. For Windows XP, you can go to edit, amend and save. But you MUST EXIT SKYPE FIRST>
To be found in
C:
Documents and settings
Your profile name
Application data
Skype
Skype User name
config.xml
Now you should check your config.xml
In CALL you shall find this entry
It should look like this
<MicVolume>255</MicVolume>
255 is max volume /// 0 AND 256 = 0 = low
Just double click on that file or use any editor like Word Pad or Word, as config.xml is a pure text file.
To be found in
C:
Your profile name
Application data
Skype
Skype User name
config.xml
255 could be much too high, so please reduce if necessary
If the volume is too high, the sound will be distorted and clipped
set for best audio quality, use echo123
Attention: MS sound recorder will NOT do this job
Save
Restart Skype
Jan 09, 2011 | Microsoft LifeCam VX-3000 Web Camera
How do I transfer files or applications from pc to the htc snap?
You need to install on your computer ActiveSync/Windows Mobile Device Center. To install this, insert the "Getting Started" CD into your computer and follow the setup steps. If you don't have the CD anymore, you can download the ActiveSync from this link.
Once ActiveSync/Windows Mobile Device Center is installed you connect the HTC Snap to your PC using the USB cable supplied with your HTC Snap, then you will be presented a configuration Wizard that will take you through the set up process.
You can connect the device to your computer using USB either as an External Drive or through Microsoft ActiveSync. If using Windows Vista, you will use Windows Mobile Device Center (WMDC) rather than ActiveSync. Simply plug the device in and choose an option on the screen of the device.
If you will use it as an External Device, you can copy data on it as you would copy on a USB flash drive, with copy and paste.
Another option is to use the bluetooth to transfer files, if you have a notebook which has bluetooth capabilities or you have a dongle.
Dec 20, 2010 | HTC Snap S521 Cell Phone
I have datalogic memor scanner. i can't connect to Windows mobile device center in Windows7. also it's driver does not work
Dear Original Asker,
Unfortunately, the older Datalogic Memor devices, which I believe your model is by the issue; model (Windows CE 6.x), can't support, and doesn't have drivers that work with Windows 7. You need Windows 6 (Vista) to use the device. In other words: all software support for the device with that firmware was dropped with the advent of Windows 7.
Solution: Update the firmware on the Memor via a Windows Vista PC, then connect the device to a Windows 7 PC.
Nathaniel Sherman
STLCC - 2012 Mathematics
MS&T - 2014 BS-CE/EE
Oct 10, 2010 | Datalogic Memor Smartphone
Hey, I own a Palm Treo 750 Windows Mobile 6.1 based device. When I connect the device to any of my computers, running various platforms such as Windows XP and 7 and an Ubuntu 8 based linux system. It seems...
Make sure you XP machine has ActiveSync v4.5 installed and running. For your Windows 7 one, make sure it has WMDC v6.1 installed and running. If you are not sure, take a look here and download the most recent versions.
However, if you find everything to be fine with your computers, your Treo might have its ActiveSync application corrupted. You could try to hard reset your device, to see if ActiveSync is fixed. If you decide to do it, it is recommended that you backup your data, to be restored afterwards, because a hard reset will set your device to its factory defaults, thus deleting every program you have installed, as well as all your personal data. To hard reset your device, open the storage card slot on the side of your device. If its screen is off, press and hold the Power/End button, and, at the same time, briefly press the reset pin (next to the card slot) with the stylus pen. Keep pressing the Power/End button until you are prompted to erase all data. Press the Up button, to confirm the hard reset procedure.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 08, 2010 | Palm Treo 750 Smartphone
How do you uninstall a program from a palm treo 750?
You need activesync
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
ActiveSync’s Tools >Add/Remove Programs screen lists all the programs that have been installed on your device. To uninstall a program, uncheck the box next to it and click on OK. To reinstall a program, click on the empty box next to it and click on OK. Do not click on the Remove button. Here's how to do it: If you used ActiveSync to install a third-party program to your Windows Mobile device, you can uninstall the program quickly from your PC.
  1. Make sure your Windows Mobile device is connected to your PC and ActiveSync is running.
  2. From the PC’s ActiveSync Window, click on Tools >Add/Remove Programs. This opens the “Add/Remove Programs” dialog box, which displays a list of third-party programs you have installed on your device.
  3. To uninstall any of the checked programs, click on the box to uncheck it and hit OK—ActiveSync will do the rest.
Reinstalling programs you’ve uninstalled Once you’ve installed a program using ActiveSync, the necessary installation files are saved on your PC. If you uninstall the program as described above, you can use the Add/Remove Programs menu to reinstall it at a later time. Uninstalled programs appear in the Add/Remove Programs list as items with unchecked boxes. To reinstall it, click on the check box next to it and hit OK. ActiveSync will reinstall the program automatically. Note that files in CAB format can be downloaded directly to a device and installed, so they will not appear in the Add/Remove Programs list. In addition, some freeware programs are installed by using ActiveSync’s Explorer to copy the program file to your device. Those also do not appear in the Add/Remove list. WARNING: Do not click on the “Remove” button at the bottom of the Add/Remove Programs screen unless you never again plan on using the program. This completely removes the necessary installation files from your PC and you won’t be able to reinstall the program by checking the box.
Jan 08, 2010 | Palm Treo 750 Smartphone
Service Pack 1
NEC Computers has developed a service pack to address several service issues with MobilePro 780 and 880 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 780 and 880 systems immediately by installing this service pack according to the installation instructions. * Download Service Pack One for MobilePro 780 and 880: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Installation * See Contents of Service Pack: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#FAQ Installation Instructions for Service Pack One for MobilePro 780 and 880 First download the service pack (MP78_UPDATE.CAB) to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP78_UPDATE.CAB file, follow these steps: 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Full (hard) reset on your MobilePro. Caution: Performing a Full reset erases all your data. Your MobilePro resets to the factory default settings. Please perform the backup first or you will lose data! 3. Copy the MP78_UPDATE.CAB file to you MobilePro desktop. 4. Install the service pack by double tapping the MP78_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. The following Message box will be displayed: Warning !!! 1. In order to ensure these patches are properly installed you must perform a Hard Reset prior to the installation. 2. You must back up all application and data files before performing a Hard Reset. The Hard Reset WILL ERASE all applications and data stored on this Mobile Device. 3. This file must be installed immediately after performing a Hard Reset on the Mobile Device (before any applications are reinstalled). 4. Press CANCEL to exit. Or Press CONTINUE to install this file. 6. Press Continue to install the service pack or Cancel to back up your data. 7. When the Setup Finish message box is displayed, Click Ok. This will remove all temporary files from your systems. 8. When the Setup Complete message box is displayed, click Ok. 9. Perform a Soft reset on your MobilePro. 10. Optionally, restore your MobilePro data using the ActiveSync restore procedure. 11. Once the service pack is installed, NECC recommends that you use the ActiveSync b
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Service Pack
Sep 14, 2005 | NEC MobilePro 880
Datalogic Memor Smartphone Logo
21 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
