Question about Kitchen Ranges
Maytag stove oven controls locked - Kitchen Ranges
Amigaman
  • 248 Answers
SOURCE: Maytag stove with a F 1-3 fault
  Have seen lock motors go bad on these.  Probably happened due to self clean heat.
Posted on Oct 13, 2007
fridgetech
  • 473 Answers
SOURCE: MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Posted on Dec 04, 2007
  • 161 Answers
SOURCE: Maytage PER5710BAQ locked!
Put it into the clean cycle. and let it clean. Then see if it will release after it completely cools If the pan of muffins or anything else is still inside don't let it clean more than 10 min. as it will catch fire. Just let it start cleaning and shut it off yourself. If you can program the clean time for less than 1/2 hour try to let it shut off itself. If there is nothing inside let it go the full amount or at least 2 hours.
Posted on Jul 03, 2008
scottowa
  • 87 Answers
SOURCE: Maytag gas Stove MGR5710 bake oven does not work. boiler works
Usually I always find it's the ignightor. They are not to hard to replace. It's #5 on this looooong link
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGR5710ADW&productCategoryId=0124002&brandId=3048&modelName=GAS-RANGE&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=X2906551&backToLink=Return%20to%20Sub%20Components%20list
Or go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter your model number and it'll kind of show you how to get it apart. Good luck.
Scott
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: Maytag Oven Door is locked
I had the same problem.  Unplugging the oven didn't solve it, as the same "F9" message appeared when restarted.
Here's what worked:  start a cleaning cycle, and then hit cancel.  I leaned on the door just a little, the latch stopped making the "clicking" noise, and then the lock light turned off and the door opened.
Posted on Jan 30, 2009
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Display panel control
I had the same problem with my Maytag range. I pulled out the stove and unplugged it. I took off the back panel that protects the digital panel that controls the oven. There was dust all over the electronics. I got a can of compressed air that is used for computers and blew all of the dust out. Plugged the stove back in and it has been working fine since then. Dust can create static electricity. The replacement panel is $300, plus labor.
Nov 28, 2013 | Maytag MER6769 Gemini Electric Kitchen...
NEED DIAGRAM FOR A MAYTAG STOVE MODEL #MGR 577 0ADW , THE OVER CARD IS NOT GIVING THE OVEN PILOT THE SIGNAL TO IGNITE
I could not make that model number ya posted work but your question sounds to me like that dude is a direct spark stove. If your top burners are lighting then you have a good spark module. That means the oven control is not getting confirmation of ignition and has tried several times and finally locked out. If it do lock out it stays locked out for a while. Also ignition is not instantaneous and you will have to allow for the process to do it's thang.
I wrote a tip for these stoves and included a service manual HERE.
Oct 27, 2011 | Kitchen Ranges
We have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Mar 04, 2010 | Ovens
F-9 code with lock sign coming on
Check for obstruction in door lock mechanism. The celenoid is behind the back panel of the stove.
Nov 20, 2008 | Kitchen Ranges
Maytag gas Oven GA347BXUWX
hi there,
if it's just the stove, it's not the control board because the rest of your stove work. if it's just the oven, it most likely the thermostat, blower or the heat probe. go to www.reliableparts.com to get parts for it.
Aug 07, 2008 | Maytag CWG3100A Gas Single Oven
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
