SOURCE: Rand McNally TND 500 displays
I suggest you reset your GPS, to reset your gps, follow
this steps, turn off Garmin device. Press down on bottom right corner of
the
touchscreen, and then power on the GPS unit. You should be prompted
whether do you really want to erase all user data, or asked if do you
really want to start up in maintenance mode. Press “Yes” to reset
(warning: all data will be erased and lost, so backup before proceeding)
or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device
outside where there is a clear unobstructed view of the sky for 15 – 30
minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
SOURCE: how do i take off
Rand is working on this. A new version may be available soon that addresses this issue.
Thanks,
Mark
SOURCE: i need instruction manual for navigator rand mcnally gps receiver
Would this be it?
http://content.etilize.com/User-Manual/1010509357.pdf
Testimonial: "many thanks for your help"
SOURCE: rand mcnally tnd 710 not turn on
If it is more than a few years old then the battery is a real possibility as the problem.
The download did not go correctly. You have a unit that is
missing or has incomplete files. Contact Rand Support and they will send you an
update card. It will not delete your user data and it will upgrade you to the
current version and with new maps. Be sure to have the serial number off the
back of the TND (bottom right) handy.Thanks Mark, Rand Lead Beta Tester
