Question about Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman)
Looking for manual craftsman 536.887990
Auger belt
2 Suggested Answers
  • 38 Answers
SOURCE: here can I find a manual for a craftsman c459-52832 or the part number for the auger belt
i assume you mean this Craftsman C459 52833 Operator Manual
Posted on Feb 02, 2015
Testimonial: "no that is a different model but I did find the belt numbers auger 754-0050 drive 754-0367 thankyou anyway"
Auger belt on single stage craftsman 536.88150
try looking on Water Filters Lawn Garden Appliance Parts many times they show a diagram so you can order the correct parts
Oct 15, 2015 | Garden
Snowblower....auger takes time to get going...like five minutes...it will struggle to start spinning then eventually warms up and is fine....whats the issue?
It is most likely your auger drive belts. There are two of them, and they need to be replaced periodically. Your manual should describe in detail as to how to replace the belts. Always start by removing the spark plug wire.
Improper gearcase lubricant could also cause problems. Your manual should tell you specifically what to use in the gearcase, and how to fill it. Also look for grease fittings on the auger and use a low-temp grease to service those fittings.
Lastly; behind the auger is the impeller shaft. Reach in and see if it wiggles. If it does, then have your impeller bearing replaced.
Feb 13, 2015 | Craftsman Snow Blower / Snowblower Bottom...
What are the belt sizes for a craftsman snowblower model# C950-52379-5
Based on the following info from SearsPartsDirect.
Will this fit my Craftsman Canadian model c9
The auger drive belt is part number 585416MA, and the drive belt is part number 1733324SM.
Feb 09, 2015 | Craftsman Garden
I have a 3 yr old 26" snow blower. I ran the machine up against hard packed snow/ice and now the auger spins freely and all shear pins are still in place. The secondary impellor functions fine. I...
I am going to assume the belt is good if the impeller it running. You can check the belt by removing the plastic cover in the center of the snow blower.
With the unit safely turned off reach in and turn the blower by hand while putting a little resistance with your other hand on the impeller. Does the shaft from the impeller to the gear box turn?
Does the shaft that the augers are attached to turn? If the impeller shaft turns but the auger shaft doesn't, the gearbox in the front is bad and will have to be replaced.
I the auger shaft turns, check your shear pins again. Sometimes they will break but still stay stuck in the holes. Actually take one out and check it.
If it is a Craftsman you can get a manual from managemyhome.com and parts from searspartsdirect.com. You will need the model number of the snowblower. The number looks like 247.123456.
Any other questions please ask. Do't forget to rate this answer!
Jan 16, 2011 | Craftsman Garden
Changing auger belt on snow blower
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
I am going to assume you have a Craftsman snow blower. If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drive the auger/blower and the belt closest to the engine drive the transmission.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Your Craftsman manual will show you step by step how to change th belt.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman 16" High Garden Tractor Snow and...
# 247.88690 belt slipping when under load . i dont see an adjustment
Unfortunately there is no adjustment for the auger drive belt on this machine. The belt is either good or bad. These belts do stretch over time. I have to replace my belt every 4 or 5 years.
BUT! Before you go out and get a new belt, get your manual and using the directions there, pull the cover off the belt area and take a close look at the belt, idler pulley, tensioning spring and cable from your handle. Be sure to follow all safety procedures like pulling the spark plug wire.
If you don't have your manual you can get one at managemylife.com. Click on manuals and input your model number. You can read, download, and print your manual for free there.
Have someone engage the auger control (push down on the handle) Take you finger and push down on the long side of the belt (the side away from the idler). A good belt will have about 1/2 inch of play when pushed. More than that or if the belt is frayed, or glazed (very shiny) on the v-sides, replace it.
If the belt doesn't look bad, remove it and turn the auger pulley by hand. It should turn freely. If it doesn't, troubleshoot why and fix the real problem. No use buying a new belt and burn it up right away because something else is causing the belt to slip. (I have seen everything from a bad bearing to an old sock wrapped around the auger to cause the belt to burn out)
You can get a new one from searspartsdirect.com. Put in your model number or the part number below and you can order it and have it shipped right to your home. Your local MTD repair shop may have the belt also.
The MTD/Craftsman/Arnold part number for the belt is: 954-04050
Feel free to ask any other questions you may have. Don't forget to rate this answer!
Jan 12, 2011 | Craftsman Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman Garden Tractor Snowblower Mounting Kit (Craftsman) Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
