Question about Tascam DM3200 32-channel Digital Mixer
Tascam dm3200 error no sound contact tascam
No sound meter bridge and all show signal but no sound did have sound before
  • sus johnson
    sus johnson Feb 24, 2014
    Hi clarrie browning, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • sus johnson
Just got a Tascam DP-01 and plug my keyboard into input A and assigned it. I clicked the record button for track one . I can hear the output in the headphones and the meter is showing on the Tascam, but...
If the track can be armed for recording, it won't show anything until you arm that track. Otherwise, check to see if you can hear anything on the main output. If so, then it's just the lights, which will not affect functionality.
Hope that helps!
Feb 12, 2011 | Tascam DP01 All-In-One Recording Package...
What does it mean when u get a service error on a tascam cd rw5000 cd recorder
I recommend contacting Tascam at this link:http://tascam.com/contact/support/ Describe your problem. As far as I can tell there were some problems with the media you could use. This article might help:http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000 You could also try contacting Sweetwater Sound and ask:http://www.sweetwater.com/sweetcare/ They have a great staff.
Oct 18, 2010 | Tascam Music
I installed my tascam mk2.under Cubase LE4. Midi tracks work good.In "set-up devices" I see the Tascam inputs and outputs.Monitor VU-meter is not moving in this audio track and consequently there is no...
Have you clicked the little "monitor" icon (looks like a speaker) on the armed audio track so that it goes orange? Once on, you should see a signal on the VU meter (assuming the line in has a good signal etc). Once recorded, turn the monitor off again to listen to the track with all the others.
Jan 26, 2010 | Tascam US-144 Sound Card
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Jul 22, 2009 | Tascam 122MKIII Single Dual Cassette Deck
My TAscam 122 is not picking up a signal from my mic leads?
What are your microphone settings in the BIOS (Basic Input Output System) in the pre-boot setup?
Apr 24, 2017 | Tascam US122 Audio/MIDI Interface with...
Sound
No sound during recording ? No sound during playback ? Both ?
Do you have signal levels on the meters at stereo/ main out ? If yes then make sure master fader is at adequate level then check to see if there's a headhone on/ off switch or a headhone volume level  knob, if so then adjust ( be careful not to have the master fader at a high level when you turn on the headphones, it hurts )  If you don't have signal on the stereo/ main out meters or you do and the above steps didn't work then we'll take it from there.
Jun 21, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam dp-01fx
I am having pretty much the same issue....
Let me know if you found a solution.
Jun 04, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DM3200 32-channel Digital Mixer Logo
35 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
