Question about Bernina Sewing Machines
Need new mains cable
What size cable please.
    Scholar:
  • 74 Answers
The cable spec will depend on your whatever your country's supply voltage is and national standards.
Posted on Feb 03, 2015
I am making half throw in the cable pattern also 2 cushions in aran wool how much wool would i need to buy
You deleted the last post as I was just about to post the answer!!
a set of aran knit cushion covers knitting pattern 99p ' to Knit ' Pinterest ...
https://www.pinterest.com/pin/353040058269560085/ Vintage Aran cushion cover set knitting pattern by knitcheap, £0.99 ... CUSHION FROM SQUARES - 250 grams of ARAN in Crafts, Knitting, Patterns ' eBay ... The possibilities for using sweaters for pillows are endless.... and would make great gifts! .... Many owl patterns on Ravelry, but don't have the seed stitch in the "body" ...
Double bed sized knitted throw - Knitting Paradise
www.knittingparadise.com/t-215627-1.html
  1. Cached
  2. Similar
I want to knit my nephew a double bed sized throw how many balls of double knitting wool 100grm balls of wool will I need please. ... im currently crocheting a large granny square bed over and currently am on ball 5 of 1000g aran wool just to ...
Knitting Calculator - LoveKnitting
www.loveknitting.com/knitting-calculators
  1. Cached
  2. Similar
The world's largest range of knitting yarn, patterns, needles, books and ... Circular · Single Point · Double Point · Interchangeable · Sets · For Children · Cable Needles · Crochet Hooks ... Convert between grams and ounces ... Roughly how much yarn will I need for a particular garment? ... Worsted, Aran, 10 ply, 4.5- 5.5 mm.
Estimating How Much Yarn to Buy - dummies
www.dummies.com/crafts/crocheting/estimating-how-much-yarn-to-buy/
  1. Cached
You need to know how much yarn to buy whenever you start a new knitting or crocheting project. You can figure out the yardage by using yarn calculations, ...
HOW MANY GRAMMS OF ARAN WOOL WOULD NEED TO KNIT TWO CUSHION COVERS Google...
Dec 27, 2016 | Sewing Machines
What size of neddles do I need for a juki MO2416N
The actual size needle depends on what fabric you are sewing. Lower numbers for light fabrics and higher numbers for heavier fabrics. I use mainly 10, 12 and 14 for normal cottons.
May 29, 2014 | Juki MO-655 Mechanical Sewing Machine
What size needle
Please ask the Janome Sewing Machine mechanic or expert tailor or you buy some near correct size needle take a waste cloth and for your sake of stitch verify.
Dec 30, 2013 | Janome Sewing Machines
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
Jan 13, 2013 | Husqvarna Viking 1
My Singer XL400 gives me error #10 saying the hoop size is wrong, no matter which hoop I use. How do I fix this?
Update: In my case, the machine was broken. The main symptoms were that when opening the machine with the embroidery arm on, the embroidery wouldn't move at all as it should at startup and the error 10 would flash immediately. However, during my debugging time and as mentionned in Singer's FAQ (http://www.futura-support.com/products/xl-400/faqs), I learnt that the order in which you put/turn on the machine, computer and accessories matters. For safety, you basically need to close everything including the software when switching hoop size. Good luck!
Aug 06, 2012 | Sewing Machines
I am trying to applique on broadcloth but my needle keeps skipping stitches a lot. I have a new sharp needle size 11 and it seems worse. Help please.
Skipped stitches
1.the needle may be inserted incorrectly,, bent,, or blunt
2.the needle & thread may not be suitable for working together
3.try rethreading the machine
4.try a different type needle for the fabric & size
Jan 20, 2012 | Yamata Sewing Machines
What size needle does the euro-pro x 384 take?
The needle size depends on the type of fabric you're using. Generally, if you're sewing heavy or sturdy fabrics you'll need a size 16 needle. If you're sewing light weight fabrics, you'll need an 11. Nowadays, most machines will take any brand of needles. I hope this helps. If it does, please return and rate my suggestion.
Jun 06, 2011 | Euro-Pro Shark 60 - 384
When starting to sew, cotton becomes knotted in fabric and machine stops. Have tried new cotton spool, new needle, checked for blockages, everything seems to be free-running. Advice please, thanks
it is possible that the needle & thread are not compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 07, 2010 | Janome Memory Craft 9000 Computerized...
My needle broke on my Brothers LS-2125 sewing machine. I need to order a new one - and I need to know how to change it. Please help!
You can use any brand of needle. The flat part of the needle faces back. Undo the little screw that holds the needle slightly until you can remove the old one. Put the new one in all the way up as far as it will go (flat to the back) and tighten the screw. I would recommend a size 14 ballpoint for regular sewing
Jan 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
21 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
