Question about Dryers
Electrolux edc 5330
To change from left to right hand
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: E50 what does it mean,
Hello & Welcome to FixYa
E50 in your Electrolux is a motor error and is displayed due to a bad motor or a bad motor capacitor. Check if the motor brushes are ok and also check if the connections to the motor are fine, if everything tests fine including motor then replacing the motor control board is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 16, 2011
Edc 03779 what's prombelm this
The fault cods EDC 03779,03778 have overlapping causes consist leakage of injectors,valve ,pipe but in some time malfunction in the high pressure pump , any one agree with me or there is any addition causes. some people have solve the problem with changing the fuel filter.
03779.....EDC ............ Rail pressure: Leakage in quantity compensation
03778.....EDC ...................Rail pressure: Leakage in overrun conditions
May 10, 2014 | Cars & Trucks
Electrolux PLHV42P8CC/two lights working two out and replacing bulbs does not fix the issue
Good Afternoon Rick,
I see that you are having trouble with the front right and back right halogen lights not working on your Electrolux range hood, model# PLHV42P8CC. I also see that you have heard of testing and replacing the transformer inside your appliance. I suggest contacting an authorized technician. It could possibly be something other than the transformer or it is possible that it is the transformer and something else that is causing the right side lights to not come on. Hope this is helpful.
-Best Regards-
WP
Apr 16, 2014 | Electrolux EFC90244X Kitchen Hood
Electrolux dryer edc 5330
its a heating problem but may not be the element could be the main board
Mar 28, 2014 | Dryers
Electrolux cooktop E14 error
Hello Winnie - Error code 14 means that there is a communication failure with the key sensor for cook place 4 (left position) - right board. Base on the intensity of the issue; contact a professional technician to diagnose the following: Test flex cable between boards, change right board, change center board (on 36" models only), change left board.
Sep 23, 2012 | Electrolux 30" Built-In Electric Cooktop -...
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 20, 2017 | Dryers
Hi. I have a electrolux EDC 5330 tumble dryer. It runs for a few minutes and then it starts to sound like it is having difficulties turning, then it opens, biiiiips and shows error code 50. My...
Hello, error50 is a motor problem. the first thing you have to do , is to look at het electronic modul in top-front of machine. There will be al lot of bad solders at the black relais. Greets Stefaan: AEG Electrolux Technician Belgium
Feb 17, 2011 | Electrolux Dryers
How to reverse door on kelvinator fridge?
Im unable to look up htat particular model number for you, looks like my FRT18, which is made by the electrolux company, in which case, YES you can easily switch the door swing form one side to the ohter, whats on the left goes to teh righ and right to the left, not a problem
Jan 11, 2009 | Refrigerators
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Dryers Logo
Top Dryers Experts
