Question about Kitchen Appliances - Others
Menvier mf 400 smoke detectors going faulty after 1 or 2 hour of reset the panel
2 Suggested Answers
  • 37 Answers
SOURCE: How can i get the tamper light to go out, so i can
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Posted on Nov 08, 2009
My alarm monitoring service tells me they are getting multiple sensor error readings from my smoke detectors. This occurs at the same time each morning. I have checked the voltage at the alarm panel
Before I can really try to answer, I would like to know what make/model control panel you have (ex: Honeywell Vista20P), the zone number of the affected smokes, and whether or not you get an indication of a problem on your keypad.
Nov 16, 2014 | Home
How do I stop the beeping of smoke detector after battery has been replaced?
How old is it? It may be telling you that it's no longer reliable and must be replaced.
Sep 30, 2014 | Kidde 4618 Firex Hardwire Ionization Smoke...
Menvier mf 400 cooper
Try re-seating the CPU, CMOS battery and memory. Not sure if you have a signal light on that board ? If you still have the same problem, check the power supply for correct voltages.
Hope this helps
Keep in mind, if you are not receiving the 3.3, 5 and 12 volts you will run into problems.
Also, when trying the above.. disconnect any external devices and internal cards, such as Video, USB, fire wire, modem ect.
Apr 04, 2014 | Computers & Internet
Fire alarm keeps going off randomly and there is no fire or smoke
What type of smokes detectors are you using. Is the Zone programmed correctly. Loose connection. Missising resister
Mar 09, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
The sensor Honeywell TC807A 1036 (Smoke Detector), is compatible with a NFS-320 Fire Alarm Control Panel?
I don't know if that particular smoke is compatible or not, but the NFS-320 is a commercial rated UL864 Revision 9 fire panel, which means the documentation is part of the UL listing. This means that in order for a device to be compatible with the system, it must be listed in the Installation Instructions as compatible. I couldn't find any mention of that particular smoke in any of the documentation I found for that alarm panel.
Oct 23, 2012 | Honeywell Tc807a1036 Smoke Fire Detector...
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Every hour my detector beeps and the green lights flashing is it carbon nonoxide or smoke or battery??
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Apr 17, 2010 | First Alert SA302 Dual System Smoke...
Solid alarm - no way to reset
Call the Consumer Hotline: 1-800-880-6788
Hours are from 8:00 a.m. - 1:00 p.m. and 2:00 p.m. - 5:00 p.m. EST
Monday through Friday (Except Holidays)
Oct 29, 2009 | Kidde DC Voice-Alert CO and Smoke Alarm
How can i get the tamper light to go out, so i can reset my alarm on the cooper menvier 9448+ alarm control panel
HTH
Oct 06, 2009 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
44 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
