Question about Alpine TDM-7574 Cassette Player
No sound from tuner
Hi connected unit into car and getting sound from cd multichanger and cassette deck but nothing from tuner. reception is very good any ideas
4 Suggested Answers
  • 111 Answers
SOURCE: No sound from front speakers during CD operation.
I think you are using an external amplifier,if this is the case,you may be using the wrong remote wire for the amp.
Alpine use two blue wires,BLUE (only) this wire is for the pwr antenna and every time you insert a cd, this pwr line cut out.
BLUE/WHITE STRIPE this is the remote wire that you need to connect the remote of the amplifier.
thanks for rating
Posted on Feb 12, 2008
  • 7 Answers
SOURCE: No sound coming from deck
check the remote wire(the blue with white) is it giving 12 volts to the factory amp? some ford have amps that needs to turn on when the radio turns on.
Posted on May 28, 2008
SOURCE: No Sound from CD but I do get sound from tuner
you have the blue, power antenna, wire hooked...
(blue/white is remote for amp)
Posted on Sep 25, 2009
How do I hook up a rsb11w dual tape deck to a technics sa450 receiver
Hi! This is normally relatively easy. You just connect the tuner output to the line input of the deck. Normally this is done with the amplifier where the tuner go to the tuner and the tape deck to its connections just line out to the cassette input and the cassette line out to the tape input of the amplifier
Oct 04, 2014 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Akai Stereo Tuner Amplifier(AA-1125).with faulty tuner
It could be that IC's that control the AM/FM radio have failed and need replacing. On the circuit diagram it has two numbered LA1240 and LA1230. Though it's unlikely both would fail at the same time. Unless you were not using the AM radio and that failed first and then the FM one went. However there is a 7 pin device which is called the Front End. This is located connected to the tuning gang. The metal thing with flanges that in-twine. Both the AM and FM aerial leads go into this before reaching the IC's. It contains a FET and some transistors. It has 12 volts on pin 4. And there is a 300ohm output on pin 3, where both FM and AM signals come out. So you can check that out. If it's not showing 12 volts on that pin there is something wrong or the 300 ohms on 3.
You could at one time get a replacement Front End, but after all this time it's unlikely they are still made. But with a lot of work it should be possible to get inside the Front End and replace the faulty parts.
The service manual is free and online. Just type the model number and service manual into google and you will see the free PDF of it. Parts numbers for the Front End are mentioned, just in case somebody still stocks it!
Jul 02, 2017 | Audio Players & Recorders
Toyota Rav4 cd multichanger??
is it in the unit itself have a look carefully if theres a load button on the unit they go into the unit if theres no button indicating this look hard for the changer should be in dash in the unit itself
Oct 07, 2009 | 2002 Toyota RAV4
I get FM reception but no AM on my '05 Jetta factory radio..help?
it might be that your gadget posses a wrong panel written AM when there is no am tuner. If you can check inside it whether it has a choke wound with copper wire for AM reception. If its missing, its aint gonna have any reception
Sep 20, 2017 | 2005 Volkswagen Jetta
Ford CD Mulichanger cassete stuck in multichanger
There should be a pin-hole on the front of the cassette, just like on a PC cd drive. Push a paperclip into the hole to release the cassette manually.
Feb 07, 2009 | Car Audio & Video
Vol problem
Here is the entire troubleshooting section from the manual.
Your problem is presumed to be a shorted speaker wire. I assume you're not getting the failure ONLY at extremely high volume levels.
Care and maintenance
Occasional care and maintenance of the unit and the software
are needed to optimize the performance of your unit.
To clean the cabinet
Use a soft and dry cloth. If the unit surfaces are extremely
dirty, use a soft cloth lightly moistened with mild detergent
solution. Do not use strong solvents such as alcohol, benzine
or thinner.
To clean the tape heads
Dirty tape heads cause sound deterioration. After every 10
hours of use, clean the tape heads with a head cleaning
cassette. Refer to the instructions of the cleaning cassette.
To demagnetize the tape heads
Use a demagnetizing cassette after every 20 to 30 hours of
use. Refer to the instructions of the demagnetizing cassette.
Care of CDs
When a CD becomes dirty, wipe it from the center out with a
cleaning cloth. After playing a CD, store it in its case. Do
not keep it in hot or humid places.
Care of tapes
Store tapes in their cases after use. Do not leave tapes near
magnets, motors, television sets, or any source of
magnetism. Do not expose tapes to direct sunlight, or leave
them in a car parked in direct sunlight.
REFERENCE
Troubleshooting
If your unit fails to perform properly, check the following guide
and the relevant sections of the Operating Instructions.
There is no sound.
•Are the speakers and AC power cord connected properly?
The unit shut off suddenly.
•Possibly a short circuit in the speaker terminals.
Disconnect the AC power cord from the AC power outlet
and re-connect the speaker cords correctly.
The unit blacks out when the unit is turned off.
•Is ECO mode set to on?
Erroneous display.
•Reset the unit.
Poor radio reception.
•Check antenna connection. Adjust the antenna to find the
best reception.
•Move unit and antenna away from other electric appliances
and cords.
The tape does not run.
•Is the deck in pause?
Poor tape sound.
•Check for dirty heads. Clean them if needed.
•Use type I (normal) tapes.
Cannot record.
•Is the erasure prevention tab of the tape broken off? If so,
cover the detection slot with adhesive tape.
The CD player works poorly.
•Is the disc correctly loaded?
•Is the disc dirty?
•Is the lens affected by condensation? If so, wait
approximately one hour and try again.
Resetting the unit
If an unusual condition occurs in the display window or the
cassette deck, reset the unit as follows:
1 Press POWER to turn off the power.
If the power cannot be turned off, disconnect the AC power
cord, then plug it in again.
2 Hold down s and press POWER.
Everything stored in memory after purchase is cleared.
May 03, 2008 | Aiwa NSX-TR77 CD Shelf System
Mar 17, 2008 | Alpine CDA-7863 CD Player
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Alpine TDM-7574 Cassette Player Logo
18 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
