Question about Refrigerators
The control panels burned of my bosch ksr390 refrigerator and Bosch GSD320 freezer. Where can I order these parts?
  • 109 Answers
SOURCE: fridge too warm
first, verify that the fan is running in the freezer compartment. second check that there is no airflow blockage between freezer compartment and refrigerator compartment. if that does'nt solve the issue verify the defrost system is working.
Posted on Mar 28, 2008
SOURCE: Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
Posted on Sep 29, 2008
  • 19 Answers
SOURCE: Asterisk symbol Bosch Refrigerator B20CS50SNS
It means it is time to change the water filter. You can hold the button down for a while and it will reset whether you change the filter or not.
Posted on Jun 10, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
SOURCE: Bosch stand alone freezer Intelligent 32 - how to defrost
Hi
I have the same refrigerator and found the manual;
"The refrigerator compartment was programmed to defrost automatically meaning you do not have to constantly clean and dry it. Copy from the manual"
Also have a look in the back for the drain outlet - very small. If that is clogged up it also cause water on the inside.
Posted on Jul 19, 2010
I live in York WA and require a Bosch Intelligent Frost Free 40 fridge/freezer.. fridge door seal. Would like to know how much... and where to purchase? Gail
you can go online and search for the part using make and model their are 100s of appliance parts suppliers or go to bosch site and either order or request a supplier by you
Apr 23, 2017 | Bosch Refrigerators
Wiring diagram for aBosch GSD320 deep freeze
Request the diagram directly from Bosch.
Dec 16, 2016 | Freezers
"ed25rfxfw01
You have a faulty cold control that needs to be replaced. Here is the part to order.
Oct 09, 2013 | Bosch KGU31164GB Bottom Freezer...
How do you know your Bosch Fridge Freezer needs defrosting?
Most home refrigerators share the same cooling coil for both compartments so in order to defrost the freezer that coil has to be disabled by pulling the plug. You havent mentioned the brand of refrigerator that you own but i am guessing that you have an automatic defrost. Can you hear a fan running inside the freezer compartment when the door is closed and the compressor in the back is running? If so your freezer will automatically defrost. The ice you probably see collects on the shelving or inside walls. Generally you can take the plastic handle of a screwdriver and gently tap the ice to get it to crack and fall off. Take care not to hit cold plastic parts or panels, they may crack or break. Otherwise I would get the model of the refrigerator and go to the manufacturers web site and post your question to get a positive answer. Good luck!
Jun 02, 2012 | Bosch Freezers
Siemens ka..n freezer problem
Look inside the back wall of the freezer to see if you have a layer of frost building. If yes this will indicate that the refrigerator is missing its defrost cycle. When you miss defrost it is usally number 1 the defrost control. Number 2 is the defrost heater has burned out and #3 the defrost thermostat. For you to look up the correct replacement parts you will need to find your refrigerators model number found most times inside the fresh food compartment. Click Here for=> Bosch Refrigerator Defrost ControlsI will be here to answer any questions you may have or if you have your model number let me know and I will help you find the parts you need, Thanks Sea Breeze
Feb 16, 2012 | Bosch Refrigerators
I have a GSD320 Freezer , after defrosting it would not start up . It sounds like the compressor trys to start up but then shuts off ? Martin
compressor problems , get a qualified tech out to test the compressor , to me its sounds like its time to replace the compressor
Jan 19, 2011 | Bosch KSR34464 Refrigerator
There is a buildup of ice behind the lower section of the plastic back panel which eventually prevents the door from closing.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch cooler fridge who cools too much
In your case I will need to assume that your model is a typical refrigerator with a defrost control and these type have parts that are made up of the major parts for the auto defrost. Auto defrost has a most likely problem found in the timer or electronic defrost control. These are most times found inside the fresh food section and behind the temperature control panel in the photo below marked a E and in that photo it shows a defrost timer in lower arrow and a electronic defrost control in the upper arrow. The next most likely problem would be the defrost heater and defrost thermostat found in the rear of the freezer compartment. Sounds like the defrost system has failed. Most Brand models We are able to handle here in the USA but your model is made ih the UK and I have tried my best to Have your dealers provide me information about parts replacement. A refrigerator is a Refrigerator and that is a fact but your models is designed for your local voltage 220 volt at 50 cycles That is normal home voltage in most countries except th USA. Our voltage for an appliance is 120 volts at 60 cycles so all the electrical components ar different and made different for different countries. When I request parts or diagrams from the UK I am always rejected. Then given a local repair center to service the brand of appliance.
Sep 09, 2009 | Bosch KIL24443 Top Freezer Refrigerator
Hi
Feb 28, 2009 | Bosch KSR34464 Refrigerator
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
