Question about Sony VAIO VGN-FS640W Notebook
Turn off alt car key - Sony VAIO VGN-FS640W Notebook
My screen turns sideways and when i download a game it turns sideways automatically
An upside down image - this is caused by unintentionalpressing Ctrl-Alt plus the down arrow key. Restore by pressing Ctrl-Alt plus the up arrow key. ALSO To change the display from portrait to landscape Press Ctrl-Alt plus a left or right arrow key. Some computers do not have this function.
Aug 22, 2011 | Compaq Presario CQ56-115DX Laptop
Battery light wont come on when key is turned on alt wont charge
First check the plug and wiring to the alt if ok The diode in the alt may have blow. one cause of this is removing the battery termanals while car is running.
Jan 03, 2010 | 2004 Isuzu Rodeo
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
How do I use the "AltCar" on my labtop?
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Dec 19, 2008 | Sony VAIO VGN-FS640W Notebook
How do i access the characters/symbols
you need to press alt and insert ascii char code for the marks.
Oct 17, 2008 | GE USB Retractable Number Pad HO98462
Background has turned 90 degrees
You can flip the screen around by holding down
CTRL + ALT AND ARROW KEY
CTRL + ALT + right
CTRL + ALT + left
CTRL + ALT + up
CTRL + ALT + down
with these keys you can flip the screen around as you want. Noting serious.
May 08, 2008 | Toshiba Satellite M30 Notebook
Sony VAIO VGN-FS640W Notebook Logo
26 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
