Question about Xerox WorkCentre 7232 VSE All-In-One Laser Printer
Fixya.com I have change the fuser by replacing the damaged fuser unit by installin fuser for xerox 7132 on xerox 7232 work centre, this error ( 010-333) has persisted. how can i resolve this problem. Or is it posssible to change the rollers since the problem was with the rollers
    New Friend:
  • 4 Answers
Nvm change 744-004 value 0
Posted on Apr 26, 2014
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Posted on Jan 10, 2008
SOURCE: Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Posted on Sep 15, 2009
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
Error 010327 in xerox work centre 5222
That error signifies a defective fuser unit. Replace fuser, part number 126K24980.
http://www.iteminconline.com/126k24980_126k24980-126k24981-126k24982-126k24983-126k24984-xerox-workcentre-5225-5230-fuser-110v-new.htm
Feb 22, 2016 | Xerox Office Equipment & Supplies
How to clear error 10-333 on xerox 7132 all in one
That error signifies a fuser problem where the thermistor does not detect the fuser coming to temperature. Need to replace fuser unit, part number 008R13022, see link.
http://www.iteminconline.com/008r13022_008r13022-xerox-workcentre-7132-fuser-110-volt.htm?source=froogle&gclid=Cj0KEQjw8u23BRCg6YnzmJmPqYgBEiQALf_XzZg4C5Qd7jYhL14rJSJWIPdkZdVrtP4kPg2RlOQFweIaAnzV8P8HAQ
Apr 26, 2015 | Xerox Office Equipment & Supplies
Kyocera xerox machine c-6 400 error
fuser related
=clear jam if any.
=reset error
clear - 1-0-8-7-1-0-8-7 -- 163---ok
=replace fuser if damaged
Jul 09, 2014 | Kyocera TASKalfa 180 Copier
Hi i have a Xerox work centre workcenter m15i which when it turn on, it display heating Error.what could b the problem.assist
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Sep 15, 2010 | Xerox CopyCentre C20 Black and White...
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Nov 23, 2009 | Xerox Document Centre 420 DC Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox 5750 error code 005
this error comes from fuser unit u have to change fuser unit
Aug 19, 2009 | Xerox DocuColor 5750 Printer
Error code
I believe your error message is "Open Heat Error". If that's the case, your fuser unit is bad. I understand that it is a new unit, although you do no specify if is is brand new or refurbished.
Now see, the open heat error comes when the temperature sensors on fuser detect a higher temperature than normal. I f that's the case you can easily confirm that by opening the side door (as if changing the toner) and feeling the intense heat coming out. If the fuser was new, then most probably you got a bad power supply board.
This is truly bad news, because for the power supply board to get damaged, a voltage surge must have ocurred. In most cases, there is also a need to replace the main board as well, for the copier starts working erratically, and loses some of its functions (such as duplex copying).
If the unit is under warranty, call Xerox. If you plan to get it repaired, or fixed by yourself, you can buy cheaper Samsung parts, for Samsung is the real manufacturer of the unit. The Samsung model is SCX-5115 gor a non fax unit, and SCX-5315f for a fax capable unit.
Good luck.
By the way, if you happen to fix the copier, or buy a new one, the only way to TRULY protect it from voltage damage is with an Innovolt SVSS protector. This is truly new protection technology and we sell them a lot here in Puerto Rico. Price is $74.95 plus shipping.
May 28, 2008 | Xerox WorkCentre M15i Laser Printer
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre 7232 VSE All-In-One Laser Printer Logo
199 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
