Question about Maytag MGC5536 Gas Cooktop
How to replacing igniter on mgc5536 cooktop - Maytag MGC5536 Gas Cooktop
Why does my ignitor not turn off?
Your burners switches got wet some how and this shorted them. Unplug this unit from the wall, allow time to dry and see if this corrects this problem. If not the switches need to be replaced.
Good Luck
Aug 05, 2014 | Maytag MGC5536 Gas Cooktop
How do I convert my maytag CSG7000CAB gas cooktop
i NEED TO DO THE SAME TO MY MAYTAG COOKTOP DID YOU FIND THE ANSWER YET?
Mar 08, 2010 | Maytag MGC5536 Gas Cooktop
All of the burners on my range started flikering at the same time and they were off. I could not stop them. I saw a little smoke escaping from the rear right burner. It finally stopped flickering and now...
yikes .. you have a very dangerous condition there ... ventalate the area and turn the gas off immediatly.. there is a shutoff valve somewhere in the gas line coming to the stove top .. if you cant find that then shut off the gas at the gas meter or call the gas company to do that for you (its free) ...
your problem is likely a loose pipe or cracked manafold .. it is leaking gas under the cooktop .. i would replumb the unit and check for cracks .. or call a professional .. your unit comes with a 1 year warranty or an additional 4 years if you bought extra coverage .. that probably wont cover a bad installation if thats the problem (unless the repair company installed the unit to start with) .. but will cover the stoves inside plumbing ..
your stove is not safe the way it is .. if you can still smell gas then you shouldnt be in the house until the gas is turned off ... windows should be open .. dont turn on lights or other things that can ignite the gas .. and absolutely dont try to relight the burners until the problem is fixed ..
Nov 12, 2009 | Maytag MGC5536 Gas Cooktop
Ignition keeps on flickering
clean the bottom of the knob by using vacium,remove the knob,pii it hten clean the area of the gas valve wen the knob possition,then return the konb
tnx gerbee
Jun 29, 2009 | Maytag MGC5536 Gas Cooktop
Igniters on my Maytag gas cooktop do not spark
u nid the serviceman to replace the ignition coil,coz its hard to replace & expensive the parts,temporary use macth
Jun 27, 2009 | Maytag MGC5536 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Disassembling kitchenaid gas cooktop to replace the ignitor switch
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 09, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Open Questions:
Maytag MGC5536 Gas Cooktop Logo
77 people viewed this question
Top Maytag Cooktops Experts
paulcarew
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
