Question about Vacuums
Oxypro carpet cleaner won't dispense the cleaning solution
reddevil6
  • 1673 Answers
SOURCE: Cleaning
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Posted on Feb 13, 2008
SOURCE: 9200 Bissell carpet cleaner, water will NOT dispense
My Bissell also STOPPED SPRAYING WATER.
I've owned a Bissell 9200 for a few months. I've used it twice, the last time most likely being around August. I attempted to use it this past weekend and it wouldn't spray. I searched all the help sites I could find and thought the solution was a clog in the heater, which many said was located in the arm. After I took the arm apart, to my surprise, THE HEATER IS NOT LOCATED IN THE ARM OF THE 9200 MODEL.
It's still under warranty, however am not located near a service center so I took it upon myself to try to fix it.
I'm just a single female who ends up trying to fix a lot of stuff herself so, I don't speak "technical instructions". But, here's what I did in the event that it may help someone else.
I unscrewed all the screws that I could on the base. I removed the cover over the motor. Doing so revealed the hoses attached to the soap dispenser. Located closer to the rollers were more hoses. On the same side as the foot lever, above the wheel is the where the HEATER is located.
Being that I was looking for a clog, I unclamped one hose at a time; inserted a safty pin into what the hose was attached to and wiggled it; re-clamped hose afterwards.
The only slight confusion may be with the screws. There are only two sizes. I used finger nail polish to mark where the small ones went.
I reassembled it, turned it on, and it actually started spraying again!!!!!!!!
So that this "blockage" won't occur again, I will take advice I've read about cleaning Bissell's hoses out after using it.
See, taking the thing apart was really nerve racking! Especially not knowing if it would even work after I put it back together.
GOOD LUCK WITH FIXING YOUR CLOG!....you'll probably need to sooner or later.
Posted on Feb 09, 2009
  • 51 Answers
SOURCE: hoover carpet cleaner F7458-900 issue
The pointed valve that is in the tank may need replacing. The two valves are a set. I just ordered some from www.usavacuum.com
Posted on Sep 06, 2009
57 varieties
  • 1653 Answers
SOURCE: My Bissell carpet cleaner model #1697-W will not
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Posted on Sep 30, 2010
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Won't dispense water
Hey Parker. I know how frustrating no spray can be when you're ready to clean your carpets.
Here's a complete list of troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Mar 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell carpet cleaner won't dispense the
heatman101
fdghd
Apr 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Too much solution being dispensed--carpets very wet--running out of solution before even 1/3 of room cleaned
The cleaning solution tank is only sufficient for part of a room, unless the room is very small.
Are you following the instructions for using the cleaner carefully? The machine has to be pulled backwards (towards you) at a steady pace in order for the vacuum to pick up the water that is dispensed. Do not use it like a normal vacuum cleaner - that will not work.
You need to start facing a wall, and pull the cleaner towards you, moving at about one foot every two or three seconds. The vacuum will then pick up the water that has been dispensed and the carpet will be damp but not sodden.
Apr 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Have lost my manual for the Oxypro
Go to Bissell.com and search their site for manuels. I just down loaded a manuel for my Bissell 1697 carpet cleaner. Its Free
Feb 08, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Won"t dispense water
heatman101
ytoi
Mar 03, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Vacuums Logo
11 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
