Question about Eclipse CD3422 CD Player
How to unlock theft mode - Eclipse CD3422 CD Player
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
Why my key will not unlock my door manually on my 2007 ford edge.why the anti theft mode is on the dash.
The manual unlock is operated by a set of small levers in the door. Either the connecting rod between the key mech and the door lock has become loose or the mechanism inside the lock itself is faulty.
Modern cars don't like being unlocked manually, you might have tripped the security system by trying to unlock the door, which could be why the anti-theft mode is giving you a warning. It's usually more of a warning that someone has tampered with the door locks and couldn't gain entry or something like that. If your car came with a manual for the security system, read up on it.
Feb 18, 2015 | 2007 Ford Edge SEL Plus
Anti-theft radio security code
Will display safe mode but you have to push the on button then you will get the 1000
Apr 10, 2013 | 1999 Volkswagen Cabrio
THEFT MODE 2003 TIBRON
put key in driversside door with all doors and trunk closed lock and unlock with key and done
Mar 17, 2012 | 2003 Hyundai Tiburon
Trouble shooting 05 colorado antitheft system. the anti theft light is lit and the vehicle will not start. we tried to unhook the battery, wait an hour and hook up, it did not work. what can we do?
do you have remote keyless entry? if you do use the remote to unlock it if not use the original key to unlock the drivers door that should take it out of theft mode.
Oct 20, 2011 | 2005 Chevrolet Colorado
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Apr 23, 2011 | 2007 Chevrolet Tahoe
My car audio has gone into safe mode need codes to unlock it. vauxhall corsa sxi
Hi.
There is no code to unlock safe mode. Safe mode means that a fault has been detected and the unit goes in this mode (kind of forced stand by) to prevent further damage.
Disconnect battery ground cable and check the wiring at the back of the unit, a contact in the connectors or a short on wiring is common cause for safe mode.
When you disconnect the battery ensure that you have the anti theft code if needed. Anti-theft is different from safe mode. In that case you get Code on display, not Safe or the triangle sign.
Regards.
Ginko.
May 31, 2010 | Car Audio & Video
How to put code into 1997 lasabre radio, i know the code.
If you are refering to the Theft Lock code, you must first push the right sequence of radio buttons to enter the un lock mode in the radio's computer. Once the radio's Theft Lock Identifier code is displayed, you then enter the un lock code into the radio. Ususally, this is a dealer operation as they have the online program to retrieve the unlock code after they submit your Theft Lock ID code. I'm wondering how you were able to get a unlock code without the dealer's assistance.
Aug 17, 2009 | 1999 Buick LeSabre
Radio anti-theft unlock
You may have to just go the dealership and see if they have a way to get the code.
Jul 23, 2009 | 2002 Dodge Dakota Club Cab
Eclipse CD3422 CD Player Logo
47 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
