Question about Nikon COOLPIX L3 Digital Camera
Nikon L3 lens stuck
My little nephew was playing with the camera. next thing i know the lens are stuck halfway through. when i turn it on it says LENS ERROR! and the shutters wouldn't close and i hear this buzzing sound whenever i turn the camera on. HELP.
  • 12 more comments
  • Anonymous Nov 08, 2007
    aaaa
  • Anonymous Nov 18, 2007
    Lens error?
  • Anonymous Dec 03, 2007
    lens error
  • ethan1 Dec 20, 2007
    whenever i turn the camera on it makes a clicking noise and the lens is out and wont go back in then it says lens error...
  • Anonymous Dec 29, 2007
    i was taking photos and the lens got stuck and everytime i tried turning on the camera it froze and it made a noise. Lens error kept appearing on the screen.
  • Monzi Feb 14, 2008
    I was taking a video on my Nikon Coolpix L3 and it was buzzing, but the video still worked. I tried to shut it off, but all it does is buzz and say lens error.
  • Anonymous Mar 27, 2008
    Nikon Coolpix L3 digital camera
    Stating Lense error - The lense is stuck
  • nikhita Apr 03, 2008
    the camera was dropped and now the lens are stuck midway and do not close and when switched on the digital screen reads the message-lens error
  • Anonymous Apr 13, 2008
    My older sis broke my camera by messing up the lenez and i tried to fix it myself but its really messed up... i tried to push the lenez back in and turned it on and it only came half way out...but now it wont come out at all
  • Anonymous Apr 19, 2008
    i have the same problem...are there any solutions????
  • khernand May 01, 2008
    lens won't open or shut by itself. light comes on no picture. menu says lens error.
  • diaz08 Jun 06, 2008
    My lens is stuck open and on screen displays lens error!! help
  • Anonymous Jun 12, 2008
    I have same problem shows LENS ERROR and tried several time re-open and also change batteries as well but still same problem, please advise.
    LENS ERROR and it's stuck problem.
  • 797 Answers
Hi:
Lens errors like this usually happen as a result of something damaging the lens in some way.
It could have been against something to prevent the lens from moving out.
It could have been dropped when the lens was out.
If the lens is impacted when the lens is out, damage can occur.
If there is a buzzing, grinding noise as the lens extends, then the probability of damage to the small plastic gears, internal guides or other internal lens parts is high.
What can be done is, as mentioned a few times in my posts, to hold the lens back or pull on it as the camera starts.
This may cause more damage, and may not help at all, but some cases may re-align the internal parts in the lens assembly. This may be worth a try, since the camera is useless unless the lens works right.
Hope I can give some help here on these.
Posted on Jul 26, 2008
SOURCE:
The lens is stuck out- it wont close and the screen reads "lens error" how can i fix this?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 17, 2010 | Nikon COOLPIX L3 Digital Camera
LENS ERROR ON COOLPIX L3 CAMERA
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2009 | Nikon Coolpix S210 Digital Camera
Lens Error
Jan 03, 2009 | Nikon COOLPIX L3 Digital Camera
Coolpix l3 lens error
Dec 28, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error - stuck half open
just check the power of battery ........ if it is ok just remove the battery .........clean the battery contacts properly and once again insert the battery ............then power on this will remove your problem
Jul 23, 2008 | Nikon COOLPIX L3 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Lens stuck in the out position
Please reload the Firmware and your problem will be solved.
Nov 23, 2007 | Nikon COOLPIX L3 Digital Camera
How can i fix a stuck lens on a Nikon COOLPIX L11?
It worked. I just gently nudgged the extended(stuck) lens to one side by hand. (the side which had the gap.) There was a click sound and the lense housing fell back in place. Sweitched off and switched on again and the lense started working fine. thanks.
Oct 18, 2007 | Nikon COOLPIX L3 Digital Camera
Lens is stuck open and making a clicking noise!
It costs more to fix than replace. It's quite asinine. And I wouldn't recommend Nikon again.
Nov 29, 2006 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
278 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
