Question about Sony STR-DE597 Receiver
Sony power amplifier stk 4142 using c1237ha protection ic my problum is relay not workig
Relay not working some humbling sound stk 4142 new and workin
3 Suggested Answers
SOURCE: Power On Displays Flashing "Protected"
The audio amplifier IC´s are on short circuit.
Posted on Sep 13, 2008
dunnbiker
  • 8546 Answers
SOURCE: Hi, having a problem with
RCA cable. It's called RCA when carrying Line Level audio; Coaxial when carrying digital data.
Does the sub work when you run speaker setup? It's in the manual.
Posted on Apr 01, 2011
Sony hcd-vx88
IC501 it's a Power Output IC Part Number STK-412-150.
Oct 21, 2013 | Audio Players & Recorders
How to unlock protect push power it will not let me use any functions
check for open resistor around the ic amplifier the big black one STK a value of one ohms acting as fusible resistor
Aug 25, 2010 | Sony LBT-LX50 CD Shelf System
Sony tva-ve170 keeps going into protect why???
Fan is broken so overheats. Same is happening with mine just need to fix fan I believe. I used it with a a office fan on top and it worked a lot longer.
Aug 09, 2009 | Sony Audio Players & Recorders
Protect comes up on my hx-c6
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 12, 2009 | JVC HX-C6 Shelf System
Audio protect keeps turning off my receiver (sony STR-DE597)
Jun 08, 2009 | Sony STR-DE597 Receiver
Protect and push power
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC if its works! if not that is the time you replace it, so it works normal again. Hope it may helps you...
Jun 08, 2009 | Sony MHC-GX450 CD Shelf System
Sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Dec 17, 2008 | Sony LBT-LX50 CD Shelf System
Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Oct 17, 2008 | Denon PMA-2000R 2-Channel Amplifier
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
Sony mhc-rg22
Your audio amplifier IC´s of your device are damaged
Aug 23, 2008 | Audio Players & Recorders
Sony STR-DE597 Receiver Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
