Question about Fujitsu LifeBook Computers & Internet
Fujitsu Lifebook AH552 battery
My new Fujitsu Lifebook AH552 is not charging the battery. After 20 minutes the charging lamp turns blue but battery is empty, meter showing 0%.
4 Suggested Answers
  • 324 Answers
SOURCE: fujitsu laptop
Kev,
This seems to be a common problem. Remove and reseat the memory modules. If that doesn't do it, remove the hard drive and all but one memory module and try to bring it up. If this works, add the other memory module and see if the whole thing doesn't come up. If not, get back to me for more ideas.
Thanks!
Ron-
Posted on Nov 26, 2007
romsky79
  • 822 Answers
SOURCE: black screen when turned on
first thing you do is to change the RAM (memory). if still black screen, you have to re-install or format again the laptop.
Posted on Aug 15, 2009
  • 59 Answers
SOURCE: touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Posted on Oct 19, 2009
How to fix fujitsu t732 when it won't power on after sleep mode?
take the battery out and unplug it. Wait a minute and put it back, then try
Jul 04, 2014 | Fujitsu LifeBook T732 XBUY-T732-W7D-002...
I have a brand new Fujitsu Lifebook AH512 laptop, have not been able to charge the battery at all, plugged in, not charging, what should I do?
If it's brand new take it back to where you bought it from and tell them. Don't try to fix it within the 12 month warranty - that's what it's there for!
Aug 25, 2013 | Fujitsu Siemens Lifebook C2230 Notebook
My Fujitsu Lifebook AH531 won't start up all all, as if the battery is dead. I've bought a new charger and the problem remains. Can anyone help please.
you need to find out if you are getting voltage to motherboard may be a bad jack if you do not have the tools bring to a repair shop
Jan 19, 2013 | Fujitsu LifeBook AH531
Fujitsu n3410 wont charge
Unfortuneately that leaves the charging circuits on the motherboard that must be faulty, "this is so rare I have seen only one in all my years of service". But I think it is a good idea to have the charge circuits tested to be sure.
Apr 23, 2012 | Fujitsu LifeBook N3410 Notebook
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
Fujitsu Lifebook does not boot up
Have you tried draining the static on your computer?
Turn off the computer
remove the battery and adapter
press and hold the power button for 1 minute
plugged back in the adapter and battery
turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
I suspect possible LCD issue.
May 21, 2010 | Fujitsu LifeBook A6010 Notebook
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
I have a fujitsu lifebook that will not charge my battery. I replaced the ac adapter, and i replaced the battery and continue to have the problem
Bad power circuit on the motherboard. Usually part of the motherboard and thus would require motherboard replacement to fix the problem.
Nov 13, 2009 | Fujitsu LifeBook A6020 PC Notebook
Computers & Internet Logo
124 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
