I am trying to connect my goodmans 1760s hi-fi to my tv . help
I want to use it as a surround sound but don't know if and how it can be done
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: i have a goodmans hi fi 1760s with the fall down
Loose the Cd player and check the mechanism or the Cd tray to see if nothing has hooked it.
You can also check the board inside the Cd player that controls the eject button, see if the wire there is properly fixed.
Do a thorough checkup of the internal part of your Cd player, and I believe you will definitely be able to fix it.
Best Wishes.
Posted on Nov 06, 2009
Testimonial: "thanks very much thats great advice an worked a treat "
Hi there I'm trying to connect my technics
are you trying to use the speaker system on your tv? or are you trying to get sound from your tv to your surround system?
you will need audio patch cables!
sound from your tv to surround:
line out on tv to line in on surround
sound from your surround to your tv:
line out on your surround to line in on your tv
Aug 22, 2011 | Sony Televison & Video
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Hello, I have this older surround set, the Yamaha AV1. I gave it to my yonger nephew, hoping he could use it with his LG flatscreen television and playstation 3. I don't know how i can get the...
All sound should go directly from its origin to the sound systm. All video should go directly from the source to the TV if it has enough inputs. NO signal ever benefits from unnecessary routing and cabling to or through a device that neither uses nor improves it.
Hint: TV's don't improve the sound or even need it if you have a hi-fi..
Aug 16, 2011 | Yamaha AV-1 System
Hi there, is there a way to get my goodmans ghc58 surround sound system to play through my virgin + box? I cant seem to find an optical input/output from the surround sound but i do have a goodmans dvd...
There is an optical output from your Virgin + box but there is no optical input in the Goomans, there is only 5.1 input. The only way to do it is to connect the re and white phono audio output from you virgin box to the red and white tv inputs on the goodmans, this will sound good but it will not give you dolby digital sound.
Dan
Nov 28, 2009 | Audio Players & Recorders
I have a goodmans hi fi 1760s with the fall down cd draw but the eject function isnt working at all help please
Best Wishes.
Nov 06, 2009 | Audio Players & Recorders
The speakers on my tv are done in , how can i get sound through anything else can i us a hi fi system
Your TV must have an adapter for output where you can connect the
cord to the input of your hi-fi system. Yes, you can use it, and control
the sound from your TV and Hi-fi. First, you must set your TV volume
to low position. Then, adjust the volume further at your Hi-fi to a
comfortable level. Let us know thru the e-mail and vote for our solution.
Sep 25, 2009 | Samsung P42H 42 in TV
Connect to dvd player
On the back panel of your tv you will see two audio inputs labeled AUDIO TO HI-FI. Plug your surround sound audio jacks, ( red and white ) into that. Plug your video jack ( yellow ) into what ever number input you are going to use for dvd, if needed. This will allow you to watch tv and hear it in your surround sound. You should also go to menu- then- audio option and turn off your tv internal speakers, this will allow your tv remote to control your volume of surround sound. Hope this helped.
Sep 07, 2008 | Hitachi 51F59 51" HDTV Projection...
I would like to connect my nintendo wii to my new LG HT752TH Hi-Fi Surround Sound how do i do it? thanks
can you tell me why i can watch my dvds with surround sound but i cant watch ordinary tv with surround sound, very frustrating. asked at the store and they sold me an rca audio cable, this has made no difference, perhaps i have not wired something in correctly, please help ?????
May 16, 2008 | Audio Players & Recorders
Toshiba CRT
Hi Keith,
Your Hi-Fi is designed to produce many watts of audio power. It would be a fair assumption that you took out the output section of the audio amplifier of the CRT.
The best way to accomplish sharing the speakers between the CRT and Hi-Fi would have been to use a switch box, that way both audio sources would be isolated from each other and whatever source was not being used would be put into a dummy load.
You need to find the Part number of the damaged part. If you open the CRT (power unplugged) you will probably be able to find it with your nose, since it was damaged and burned up.
Call MCM Electronics with the part number and see if they can cross reference a replacement for you.
http://www.mcmelectronics.com/
1-800-543-4330
Good Luck,
- Jim
Jan 24, 2008 | Toshiba 32A33 32" TV
Hooking uo a surround sound system
I have never used the "hi-fi" secion on the back of the TV. I have an HD DVR box and I run an optical cable from the box to my amp.
Jan 14, 2007 | Hitachi 43UWX10B 43" Rear Projection...
26 people viewed this question
 Grubhead
Grubhead
