Question about Casio DR-210HT Scientific Calculator
Ribbon printer ink is very faint
Printing is very faint How do I change the ribbon on this model?
Printer not printing very faint
Clean or deep clean the black printhead. Go to 'printer properties' then 'maintenance' and click the appropriate button.
Feb 22, 2015 | Canon Pixma MP450 All-In-One InkJet...
I am a Reseller and one of my client is having Citizen CLP-7202e. due to the faulty print head we have tried to change the print head and after changing a new print head, printer is not printing...
I have used this type of printer before. Long ago when it was called the C-ITOH. However, never had to change the print head before. I would imagine that if you did - all the adjustments would need changing. Bad Gap would skip labels and bad pressure would make them too light or too dark. If there are any vertical lines (even faint) the print head is damaged. Also, these things are very specific as to media vs ink roller. You cannot use a paper ink roller with mylar labels. Vise versa works but those rolls are more expensive. I am sure you have tested this already but you point pretty exclusively to the "new" print head with your testing. Sounds like you have answered your own question. I would do some continuity tests on the head to see if it carries any current at all. Good Luck!
Jun 14, 2011 | Citizen CLP-7202e Thermal Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
Sketchy printing, yellow and black very faint
Try to change the inkjet cartridges for the black and color because you may only be able to get no more than 105 pages out of a cartridge, assuming it hasn't gone through a cleaning process which uses up a lot of ink.
Unfortunately, most ink jet printers have very expensive ink for printing small jobs, compared to say a laser printer.
Dec 19, 2010 | Canon i950 InkJet Photo Printer
I have changed all the ink cartridges on my Brother MFC5440CN it
Light/faint prints usually are a result from clogged ink or air bubbles between the cartridge and print head (thus changing cartridge wont fix problem). Try printing the test page print from the machine (Ink Management -> set/ok twice). Answer the question(s) in the display and repeat this up to five times. The colors should be improved after 1-3 test prints usually.
Jun 03, 2009 | Brother MFC-5440CN All-In-One InkJet...
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
Card printer is not printing in colour
You have probably bought fake color ribbons , or you have taqken of the blue cup with the rfid inside.. Wich tells the printer what kind of ribbon installed
Nov 19, 2008 | Datacard SP35 Printer
Casio DR-210HT Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
