Question about EXPOBAR Office Control Espresso Machine
Export control timer - EXPOBAR Office Control Espresso Machine
How to remove write protection in usb
  • Start Menu -> Run -> type 'regedit' (without the quotes) -> Hit Enter !
  • Now take a backup of your registry, incase something goes wrong:
    Right Click on 'My Computer' -> 'Export' > save it on the Desktop.
  • Now Browse through these tabs:
    My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
  • Double click on the string 'WriteProtect' and change the 'Value Data' box to '0'
  • On Toolbar, Click on File -> Export -> Save it anywhere with any name like 'WriteProtection01.reg' or anything.
  • You need to repeat the step 3 - step 5 with every string on folder named 'ControlSet***' (* = any Digit, i.e. 001, 002) - that is, instead of currentcontrolset, repeat the steps for folders controlset***
    For Example :
    My Computer\HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\StorageDevicePolicies
    - Again export it on same directory as before, named as 'WriteProtection0**.reg'
Note : These exports are just incase you need to revert the changes in your registry, to revert, just double click on the *.reg file, and click yes when it prompts.
Oct 31, 2010 | SanDisk Computers & Internet
How to i export my Vista Windows Mail email to Outlook 2007 since i'll be upgrading to Windows 7 very soon?
To export the messages from Windows Mail follow these steps:
1. Open the Windows Mail, on the File menu, point to Export, and then click Messages.
2. In the Windows Mail Export Wizard, click Microsoft Exchange, and then click Next.
3. Now, click OK. This will export messages from Windows Mail to Microsoft Outlook or Microsoft Exchange.
4. To specify which files to export, click All or Selected Folders, and then click OK.
5. On the File menu, point to Export, and then click Messages.
Check this link for more information:
http://support.microsoft.com/kb/196347
Good Luck!!!!!!!
Oct 09, 2009 | Microsoft Windows Vista Ultimate Edition
Code 10 cd/dvd
Lets follow this:-
1. Choose Start > Run..
2. Type regedit in the Open text box and click OK.
3. Expand my computer - Expand HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder.
4.On the right hand side, you'll find upper and lower filters, select them one by one and delete.
5.Restart PC and hope it works for you.
Note:Create a restore point before you delete any key from registry.
Thanks
Oct 07, 2009 | Computers & Internet
Both my export controller and my windows installer dont work
hi,
first get in to start - run - services.msc. check wther windows installer in started or stoped. - if it is already running restart the service.
2. uninstall the existing itunes by going into add or remove programs.
3. reinstall the latest one.
Sep 24, 2009 | Computers & Internet
Export controller has stopped working (vista 32 bit)
Deinstall it. If you got this with iTunes 9 deinstall that as well and go back to the previous versions which can be found on the Apple website under support. I got rid of both of them and reinstalled iTunes 8.2.1 with quicktime and all of the various programs that were giving me "stopped working" messages all started functioning properly again.
Sep 17, 2009 | Apple Computers & Internet
Error code: 0XEB020B88 when I try to burn music CD's with cyberlinkDVD suite
do the following
Open Notepad (START>>>RUN>>>type in notepad)
Hit OK
Copy the contents of the CODE box, not including the word "code"
Paste it to the empty Notepad file
In Notepad click FILE>>SAVE AS
Change the Save as Type to All Files.
Name the file as Export.bat
CODE regedit /e Export.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
Double click on Export.bat, a text file called Export.txt
should produce on your desktop
Copy>>paste back here the contents of Export.txt
Jun 23, 2009 | Computers & Internet
Export ledger tally to excell
my name is saurabh yadav
i want to know that how export my sales book ledger export to excell form tally 7.2
Mar 10, 2009 | Tally T2245 Matrix Printer
EXPOBAR Office Control Espresso Machine Logo
14 people viewed this question
Top EXPOBAR Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an EXPOBAR Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
