Question about Logitech Z313
Disassemble shark sk460
Would like to take the handle off
  • Jackson Thompson
    Jackson Thompson Jun 05, 2014
    Under the cord clip there is a hole. Stick a screw driver in there and it will depress the tab that holds the handle in place.
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
Hi I purchased the Shark Steam Mop and tried to put it together last night. The handles will not go together as shown. It this a usual problem? Therefore I could not use the product.
From what Im reading and finding. The Shark
steam Mop. Does have some handle issues.
You can go to reviews.shark.pro.steammop.
My advice and recommendations..
Before you attemp to use the mopmake sure
That you have read everything.about it..
Ellen
Dec 23, 2014 | Shark S3101 Steam Mop Hard Surface Cleaner...
Take off the handle from shark sonic duo
http://www.sharkclean.com/shark-sonic-duo/pdfs/KD450-Owners-Manual.pdf
the pdf manual on the shark.
also customer support number:
Shark Vacuum Customer Phone Number Shortest Wait Best Support
Phone Number
800-798-7398
Average Wait: 7 mins - Mon.-Sat., 7 a.m.-11 p.m. ET
Nov 05, 2014 | Shark Sonic DuoTM Carpet & Hard Floor...
How to change the power cord on Shark NV502
Shark is not made to repair and there are no parts available. It's disposable. Most vac shops won't touch them.
Oct 10, 2014 | Euro-Pro Shark SC-505 Handheld Steam...
How to disassemble Shark Mop s3601? I took all
You need to remove the shark and power button sticklers. There is two screws in each. Once you remove the screws you slide the grey cover and remove 3 more screws holding the chrome piece. Now you can spread the cover open. I just replaced a torn hose.
Oct 10, 2013 | Shark Euro-Pro Professional Steam Pocket...
Steam coming out from handle not mop pad
Hose is off or broke at bottom of handle...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need a replacement handle modle S3101C
Look under the manuals link... they sell replacement handles...
heatman101
Mar 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Broken handle
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
Jan 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-pro Shark steam mop has a broken handle.
I have broken 4 shark handles, have repaired them its a pain. remove the screws on the handle end of the head pop out the broken handle part, drill a 3/16 hole into the part tap 1/4 inch threads use a countersunk head 1/4 inch bolt screw it together put epoxy on the inside to lock threads reassemble. its a pain. two small keepers lock the swivel together pry out with a screwdriver carefully dont loose them. I broke one shark handle when it was brand new. this repair works good if you like alot of fooling around
Jan 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam comes out the handle
You need to disassemble the wand and apply thread sealant tape to all joints. This should solve the problem.
Ray
Dec 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Logitech Z313 Logo
467 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
