Question about LG WM2101H Front Load Washer
Had a massive water leak during the washing cycle coming from the bottom
praky16
  • 744 Answers
SOURCE: My machine has a small water leak though the door during washing
hi try to Plug off the machine form wall. Open up behind the machine, you will find a thin rubber tube going from the pressure switch near control panel to the pump and exit area..... remove this tube from the top & blow into it, it should be free from any blockage or damage, refit. This tube regulates the water level and switch. If  its found to be damaged, replace it and that will work out for u...
Posted on Feb 10, 2009
  • 1382 Answers
SOURCE: leaking water from my lg front loader during
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Posted on Jun 13, 2010
kelvin971
  • 6 Answers
SOURCE: Whirlpool front loader WF665/1 spilling water during cycle
Ours was blocked. I fixed it here: http://www.fixya.com/support/t12512233-whirlpool_wfs1273bd_leaks_water_from
Posted on Aug 27, 2012
canthony673
  • 14 Answers
SOURCE: small ammount of water leaks at bottom of door during wash
Open the door. At the bottom of the gasket on the machine there are three little holes. The is where the water drains. Make certain they are not plugged. Use a close hanger or tweezers to pull what's pugging it or push in threw to unclog it. If that doesn't work, look to see if the door is crooked.
Those things get clogged easy if you have pets that shed hair. Should be checked once a month.
Posted on Jan 24, 2013
  • 96 Answers
SOURCE: LG WASHER WATER LEVEL
Newer washers use much less water than old ones,, energy efficiency etc.....
Posted on May 25, 2013
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
The washing machine is leaking water and it is coming from underneath the washer during all filling cycles and running cycles why?
Could be several things. Check all the hoses, water pump, water valve also check if water is coming from the bottom of tub could be tub seal. Check that there is not a leak in the outer tub somewhere I had one that had a nail stuck in one of the holes in the inner tub and rubbed a hole in the outer tub. Have fun I hope this helps.
Aug 28, 2011 | Washing Machines
Whilst wash on, water leaks from the underneath of washing machine. but cant see where it is coming from
if the water is leaking during the fill cycle when the detergent is being added from the drawer
ensure the draw is clear, if too much deturget rests has blocked the vent then water maybe running out on the inside.
if the problem is happening during the wash cycle this indicates a leak on your drum, ensure your door seal is intact and not leaking.
if the problem is during pumping, ensure that the pump is not causing a problem
maybe open the bottom vent and ensure the cover is seated properly and pump is clear.
also check the outlet pipe is not blocked or leaking and water is running back on the outside of the outlet pipe and under the machine
I hope this was useful.
May 23, 2011 | AEG Washing Machines
My ZWD1471 started leaking during the drying cycle recently. It doesn't leak during the wash cycle. The water seems to be coming from underneath the back of the machine, I think on the righthand side. Any...
open it and see where the leack come from it might be the drain pump and it easy to replace or it might be a hose that got burst...
see if you can open it from the back or the bottom front
Feb 07, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WATER IS COMING OUT FROM THE BOTTOM OF THE WASHING MACHINE ONCE THE WASHING HAS STOPPED, IT DOES NOT LEAK DURING CYCLE AND IT SPINS AND DRAINS FINE..
i would inspect both the hoses on the pump
no leak during cycle is explained because water is moving through them to fast to leak when the machine settles it starts to leak
Oct 15, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
LG WM2101H Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
