Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Bin not full before shutting off
Machine shuts down before bin is full
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Replace the bin thermostat.
Posted on Nov 19, 2014
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 4 Answers
SOURCE: scotsman ice machine CME 1056RS\r\nThe bin full
change the board and eyes at the same time.
Posted on Nov 29, 2010
Ice bin full does not shut down.
It really helps to know the model and make of the refrigerator. The full bin on some models have a bar that gets raised up and if the bin full, the arm gets raised high enough to open the circuit for ice production. When ice is used the bar lowers and a Microsoft in the controls shut starting the ice production again. If bar is missing it will keep making ice until you raise the bar to the off position.
If you have one of the new type ice machines, some of them use infrared sensors and thermometers and the like to sense ice production.
If you have a fairly new refrigerator, it may be still under warranty and for small fee a factory trained representative can analyse cause and replace broken parts under warranty. Warranty information will be in the information package that comes with the machine.
Hope this helps!
Apr 19, 2016 | Refrigerators
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Cme256 scotsman
Remove and clean or replace the bin control sensors ( set of two ) part number 11-0540-21. Most of the time you can remove them and clean the little lights and this will do.
Jun 27, 2013 | Kitchen Appliances - Others
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Bin control
The bin control shuts it off when the ice bin is full. Without a bin control it should keep making ice and never stop.
Dec 27, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
83 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
