My rca rlc3210 keeps turning off - Televison & Video
Why does my rca cambio keeps turing itself on and it's turned off
Checked the programming set up or call RCA tech support or call a dealer for help
Apr 05, 2016 | RCA Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My rca rlc3210 is flashing a black screen every 2-3 seconds
You need to replace the power board, i have the same issue and am looking for where to find the part
Aug 20, 2012 | RCA Televison & Video
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
My RCA F32650 32" TV keeps turning on and off. I
hi there! i hope this will help u find the solutiuons:
1. replace the power transistor at the horizontal section of your tv by desoldering . and buy with the same value, the store assistant in your area will do help you replacing the defective part of your tv. Thank You.
Feb 06, 2011 | RCA F32650 32" TV
Trying to get the code for RCA tv model RLC3210 to conect to the remote control for Bell Satellite
i had this problem also - however eventually by using the "scan" method rather than trying individual codes i was successful - of course there is no report of the code found
Sep 28, 2010 | RCA DIRECTV Satellite Remote Control
How reprogram my universal rca remote control
hold the tv button down and keep it down and then press and hold the power button down and hold them both until the power button stays red then let go of both buttons then keep pressing the power button until the tv turns off and as soon as it turns off press the stop button and it should work.
Aug 31, 2009 | RCA RCR815 Remote Control
RCA M202E keeps turning off
Is the hold on?
There's a switch on the top, try and moving it to the right.
May 13, 2008 | RCA M2000 MP3 Player
My Rca Lyra Mp3 keeps shutting down by itself and what must i download to make it compadible with windows vista
Try updating the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/)
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Aug 15, 2007 | RCA Lyra RD1021 MP3 Player
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
