Question about Canon Pixma iP6000D InkJet Photo Printer
CANON K30238 where to find used part
Lens mount fit
None directly. The T90 was the last Canon camera to use the older FD lenses. All newer Canon SLRs, film and digital, use the EF mount. However, by using an adapter such as http://www.rakuten.com/prod/adorama-canon-fd-lens-to-eos-body-adapter-with-correction-glass/216466533.html?listingId=120668308, you can use the old lenses on any Canon digital SLR.
Aug 12, 2013 | Canon T90 35mm SLR Camera
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
How to use canon pixma mg3150 printer
Hi can someone please tell me how to scan a document using the canon mg3150 please thanks
May 06, 2012 | Canon Office Equipment & Supplies
Can i use pg-40 ink for my canon mp480
Sorry you can't use PG-40 on MP480. Canon MP480 printer takes only Canon PG-510 Black Ink Cartridge, Canon CL-511 Colour Ink Cartridge or Canon CL513 Colour Ink Cartridge (this one is high yield colour cartridge).
Feb 02, 2011 | Canon Pixma MP480 All-In-One InkJet...
Have canon powershot what is best to use a 2gb
Hi and welcome to Fixyah,
I believe that canon can only use SD card you can used 2gb sd card.
Mar 18, 2010 | Canon PowerShot S2 IS Digital Camera
The function detecting the remaining ink level is disable
Hi, are you using Original Canon supplies or are the cartridges you are using are refilled/ or non-canon supplies? If they are not original Canon supplies I'm afraid the use of the "ink gauge" is one of the features lost when refilling your cartridges or using non-original supplies. If you get a new set of supplies (Canon branded) the gauge should work again .
Oct 04, 2009 | Canon PIXMA iP6220D InkJet Photo Printer
Although using canon inkjet cartridges 40 & 50
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-4
Aug 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Sunpak PZ 4000AF for Canon EOS 35mm SLR body
Canon digital uses E-TTL metering for best flash results, the older Sunpak unit isn't compatible with this, so it is not fully compatible. It may work in manual mode - but won't be as good as a more modern compatible digital flash like the Canon or Metz (eg 58AF1 Canon) versions.
May 11, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
Mar 20, 2008 | Canon I990 InkJet Photo Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
old marine
old marine
