Question about Comfort Line Products Spa-N-A-Box Portable 6 Spa
EN1 On Spa What does it mean
The pump model is CL250-c 250-CSIMW spa-n_bag 6"
    Problem Solver:
  • 7 Answers
Hi, if you are seeing an EN-1 code, there isn't any troubleshooting that can be done to resolve it. This code indicates an electrical issue internally, the Power Pack is unable to register the temperature of the water. The unit will need to be serviced. Please contact Oceantis at (855) 772-6269. Oceantis is the only authorized service provider for all of Comfortline Products Spas in North America.
Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Posted on Jun 05, 2014
What is the flow rate (GPM) of an Executive 56 Waterway pump Model PF-50-2N22F?
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C
Features:
  • Executive spa pump wet end designed specifically for 56-frame spa motors
  • Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
  • Two speed spa motors have four sets of insulated windings for increased efficiency
  • 56 frame spa motor for added strength, cooler operating temperature and longer motor life
  • Large 2-1/2 inch intake for improved flow performance and reduced noise
  • Large 6-1/2" diameter wet end for higher head pressure
  • Split capacitor, (start and run) for less energy consumption
  • Thermally protected to extend life expectancy of hot tub motor
  • Highly versatile wet end can be rotated every 90 degrees
  • Viton seals
  • Three year manufacture's warranty on spa motor and spa pump wet end
Jun 05, 2015 | Waterway Garden
I have a new spa and he says an error E98 by other models it means water to hot but my water is just 13 degrees Celsius how can i fix it ?
that often happens when there is a reduced flow of water. it heats up too fast and cannot circulate to the spa causing it to overheat when the spa is in reality not hot
Apr 26, 2015 | Pool & Spa
What does EN1 Code mean
Feb 09, 2014 | Comfort Line Spa 2 Go Portable Spa with...
Emerson pool spa pump leaking water-how to change gaskets
Emerson is not the name of the pump, that's the brand of the motor attached to the wet end, and the two together make a pump.
1081/1563 only means that it meets the standards for a pool motor.
provide make and model, for your pump.
Jan 23, 2014 | Emerson Pool & Spa
The error "en1" , pump
the pump is giving a EN1 Code. What does that mean
Jan 19, 2011 | Comfort Line Spa 2 Go Portable Spa with...
My pentair legand II cleaner rolls everywhere but doesn't **** anything up
Almost always with these pool cleaners, this means that either the debris bag is full or that you have a hole in the bag that is preventing proper suction of debris. Check the bag and clean or replace if necessary.
Nov 08, 2010 | Pentair White/Gray Legend Platinum...
Same Issue
the pump stop so will not drain spa dip # 4 may turn off for the delay but not sure if the pump will still turn off since this is new tech. good luck
Jul 05, 2009 | Jandy Aqualink Rs4 One Touch Control...
I have a coleman spa about 4 years old that is leaking, should this be repaired by a plumber or would it take a spa repair person. it is a 6 to 7 person tub coleman horizion
this has to do with where the water is coming from.
1. wall fittitng. just remove it, reseal and replace
2. pump leaking, usually means shaft seal.
3. plumbing fitting. usually just replace the fitting.
4. fiberglass cracked. get a boat repair man and have him fix it. these guys are usually pretty good.
David
May 18, 2009 | Pool & Spa
Pump/heat machine doesn't work - En2 message displays
En1 or OH means, your sensors are blind.This can happend
1) calcium, you don't use enough against it.
2) alga, you don't use enough chemical
3) acid, you don't have correct Ph value.
if you take care of the above issues, you never will have this code.
Mar 07, 2009 | Comfort Line Spa 2 Go Portable Spa with...
Comfort Line Products Spa-N-A-Box Portable 6 Spa Logo
130 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
